Just ring me man, Ill be able to do more for you that way. What state are you in?
Fill in your location so we know more about you.
Edited by LittleRedSpirit
TODA OVER SIZE HIGH COMP FORGED PISTONS C/R 12.5:1
H BEAM FORGED CONRODS
ARP HEAD STUDS
ARP CRANK STUDS
KELFORD 194-C RACING CAMS
FULL HEAD RECO PORT N POLISH
SUPERTECH 1mm OVER SIZE VALVES
SUPERTECH RACING VALVE SPRINGS
TOMEI CRANK CAPS
TRD 0.8mm MULTI LAYER METAL HEAD GASKET
TODA TIMING BELT
TRD RACING IGNITION LEADS
TRD OIL FILTER
ALL ENGINE PARTS BALANCED
JASMA RACING EXTRACTORS
Thats the work iv done to my motor, I'm currently running a razorback ecu
this is an interesting thread lol, i am also undergoing a 20v conversion, although mine is a blacktop, correct me if i am wrong but i think the only main issues with fitting a 20v, is replacing the distributor with coil over plug like willis said, or remote coils, which i am using, (ls1 coils, custom leads, mounted on firewall),
with a haltech sprint 500 ecu and the flying loom which comes with it, i think there is a blanking plate which still uses the cam sensor plug, which significantly frees up space at the rear of the engine,
as for the cooling system, the setup in the sprinter i pulled the engine out of was not running the heater circut, i don't think, so i am not sure how this will be modified in the ke70 yet, so any help will be helpful haha, but stick with the silvertop, will not be disappinted, they go hard haha
cheers, rhys
Yeah, you don't NEED to go coil-on-plug and an ECU for a blacktop. They're MAP sensored so you can just run stacks, relocate distributor, sort out cooling system and you're laughing. In stock guise it's the easiest/cheapest option to do it right. I think so anyway
Edited by Willis
