irokin Posted June 8, 2003 Report Posted June 8, 2003 Well my KE20 is boosterless which makes braking a very intense job. I want to add a brake booster but with minimal modificating. Any suggestions on what I should do and what I will need to do? Quote
Super Jamie Posted July 7, 2003 Report Posted July 7, 2003 get your brakes bled properly, or get a bigger MC you can fit remote booster kits, ask a brake shop about these or go googling if you want an inline booster you'll have to f@$k around with pedal mounts and pushrod positioning and bolt spacing, the easiness of which all depends on wether or not you have someone with a welder and some metal skills close by Quote
Super Jamie Posted July 7, 2003 Report Posted July 7, 2003 but i would start with a proper brake bleed. loke by a proper brake shop. if your lines are rusty get them made up, make sure your discs and drums are within spec and youve got enough meat on the pads and shoes none of us have problems with even ke70 brakes and just a stock MC, so i suspect the weakness in your system lies elsewhere Quote
irokin Posted July 7, 2003 Author Report Posted July 7, 2003 would NOT be surprised it the lines are shitty....until i can get ALL the lines replaced (the pads are fine..replaced them less than 2 months ago) ive adopted a double pump breaking method....basically I grab fluid then quickly release and re-apply grabbing more fluid making it heaps easier to break...but thats when I'm fangin Quote
demuire Posted July 9, 2003 Report Posted July 9, 2003 If you're having to pump your brakes sounds like you have air in your lines or something. Quote
irokin Posted September 7, 2003 Author Report Posted September 7, 2003 It was the drums by the looks...we ajusted them properly and bingo...nice stiff brakes... I would still like a booster none the less! Quote
Redwarf Posted September 8, 2003 Report Posted September 8, 2003 In a KE20 there's not much point. The best thing you can do is put a better brake master cylinder in. I currently run a Suzuki Swift one, but am about to put an RX2 one in, to see how that goes. If you can lock up your brakes fairly easily, you don't need a booster. That's the beauty of a car that weighs bugger all! Cheers R P.S: Apologies for sounding like a smart arse! Quote
irokin Posted September 8, 2003 Author Report Posted September 8, 2003 haha... as long as your imformative i don't care. I can lock them up..if i jump on them...theres a few more pipes that need replacing and the master cyl is all of 30yo so I'll start replacing parts and see how it goes! Quote
