May 2, 201214 yr comment_601284 Hey guys, just having some issues with my front left window. Basically my window winds down, and it also winds back up but it only goes about 4 5ths of the way up and then it just stops and when you wind it just makes odd noises slightly like its grinding or what ever. Has anyone had a similar issues? If so post below with how you fixed the issue.. Or if anyone in lives in Brisbane, and would like to come round and give us a hand to attempt to fix the issue, give me a call or text on 0402280709, or just leave a message below cheers :) Ill happily pay for any assistance.. Report
May 2, 201214 yr comment_601290 the front of the window will have come off or out of the bailey channel. If i remember correctly on that door the rubber is ʞ©$ɟed and I bodged it up. New bailey channel rubber can be bought from Clarke Rubber. Report
May 7, 201214 yr Author comment_602337 the front of the window will have come off or out of the bailey channel. If i remember correctly on that door the rubber is ʞ©$ɟed and I bodged it up. New bailey channel rubber can be bought from Clarke Rubber. Nah that was the right window, took about 2 hours and some crc to loosen up the seal, it's something to do with the winding mechanism on the left one.. Does anyone else have any ideas? Report
May 7, 201214 yr comment_602345 Hey mate, I've fixed this issue a while back, It is most likely the final few teeth on the window winding regulator. You will need to remove the inside door card (3 screws), Unscrew the window from the winding mechanism (2 screws) and then remove the window regulator which if i remember correctly is another 2 bolts. You will unfortunately need to purchase another winding mechanism though... Cheers, Justin Report
May 7, 201214 yr Author comment_602504 You don't have any photos do you, from when you did it? Also do I have to replace the entire unit or just the cog that winds the window up? Haha if your in qld I'd pay you to come help.. Edited May 7, 201214 yr by chrisfindlay Report
May 10, 201214 yr comment_603139 Hey mate, I would definately come past and help you out but i'm in a different state haha, did you manage to fix it yet? I'll see if I can find a spare mechanism lying around and i'll take some pictures. Cheers, Justin Report
May 13, 201214 yr Author comment_603571 Hey mate, I would definately come past and help you out but i'm in a different state haha, did you manage to fix it yet? I'll see if I can find a spare mechanism lying around and i'll take some pictures. Cheers, Justin Nah not yet man, it sucks ass!! If you want you can send them to my mobile - 0402280709 Report
May 13, 201214 yr comment_603596 Hey mate, I'm on the Gold Coast, I also have the exact same problem! If you solve it can you PM me? Report
May 13, 201214 yr Author comment_603714 Hey mate, I'm on the Gold Coast, I also have the exact same problem! If you solve it can you PM me? Sure bud same to you! Report
August 24, 201214 yr comment_622956 had the same issues with all mine :( just opend the door panels and used cloth tape and taped it back on the rubber bit :) cheapest way :) been working fine for 3months now :) yay ! Report
