June 6, 201214 yr comment_608282 1) Tappets - adjust to suit and/or chain guide/tensioner if one 2) Brakes - Worn rotors I'm guessing Report
June 7, 201214 yr comment_608420 This may sound a bit weird, but I had a similar noise to yours. It ended up being the retaining clips that hold the lid of the air filter on. I had tightened the wing nut a bit too much, leaving the clips loose enough to rattle. Although, my noise was fairly constant through the revs. I felt like a right knob after I worked it out haha, thinking it was something bad. Just thought I'd share on the off chance it was that, probably not though. Report
June 7, 201214 yr comment_608432 Sound alot like a Brocken bracket for a steel pipe sort of like when you have a Brocken exhaust bracket try feel around the engine bay for the vibration Report
June 7, 201214 yr Author comment_608481 air box only has a wing nut ill checck when i get the timing chain and shit done gota do engine mounts just got them today Report
June 8, 201214 yr Author comment_608692 just bought two engine mounts gear box mount sump gagsget and timing cover gasget set all up of 175.64 Report
June 11, 201214 yr Author comment_609244 all back to gether now and running thank god its manual had to bump start it because somthing is wrong with the starter motor now i just get clickiing noises when i go to cranking Report
