sup :) iv got a ke70 with a 20v 4age fully worked N/A pulling 128kw atw. my fuel pump is on the way out and not sure what to get, the fuel pump i have in atm was from the previous motor which was a stock 16v, please help us out and reccomend a fuel pump that fits etc, trying to avoid external :)
THANKS <3
So you just want to run a single EFI pump in-tank?
The most common solution to every carb to EFI conversion I've read about is the VL in-tank lift pump + VL external EFI pump. The VL pumps will easily feed a 128kw 4AGE. Or you could just go with a Walbro in-tank EFI pump, they are also quite common.
Walbro 255 (as in 255 litres per hour) is the one I've heard/read of people using. It will work fine but it's a humongous pump for a 4AGE. Stock 4AGE pumps pump 80lph, so I'd try and find something around that, maybe a bit bigger if you want. Walbro make heaps of pumps, try and find a catalogue and get some specs on them.
Edited by rian
I think he is taking about my old car, so it is already setup as per my tech articles floating around. That Bosch external pump was in unknown condition when I got it, so I wouldn't be siprised if its past its use by date.
If you have Dave's old car just get a replacement Bosch 070, which is the external VL EFI pump I was talking about early. Will just be a straight swap, no mucking around changing stuff.
TODA OVER SIZE HIGH COMP FORGED PISTONS C/R 12.5:1
H BEAM FORGED CONRODS
ARP HEAD STUDS
ARP CRANK STUDS
KELFORD 194-C RACING CAMS
FULL HEAD RECO PORT N POLISH
SUPERTECH 1mm OVER SIZE VALVES
SUPERTECH RACING VALVE SPRINGS
TOMEI CRANK CAPS
TRD 0.8mm MULTI LAYER METAL HEAD GASKET
TODA TIMING BELT
1ZE COIL PACKS
ITB's
thats all i can think of off the top of my head lol
its the intank one thats playing up the little black box looking thingo ! its making a shit tone of noise now and its cutting off at times, i replaced the external pump. what intank one should i get ?
