hi guys,
so, i got lucky and talked Ryan into doing a deal for his EL31 GP2 Turbo
specs are:
3ete 1.5l turbo
4spd auto(3spd plus O/D)
TEMS adjustable suspension
this beauty only has 108,000 k's on the clock, and it shows..!
everything still feels near new
plans are to tint the windows, proper lowered springs, and get a decent exhaust
restore the paintjob, redo the stickers on the drivers side
then drive to the RC meets and shows, til something breaks, can't find parts, and cry
pretty much how i got her
more to come
Edited by nerfbat
  • Replies 30
came with a RWC so all i had to do was race to the Dept Of Transport when i finished work on Friday to register her.
Rob and I, drove to Dave's work to show him and take her maidenhood, well sorta, and give her a short cruise
but i didnt want to drive her much til i changed the oil/filter/auto fluid etc
washed her today, and took her for spin, after the service
took some pics at Uni along the way
came across this info when searching today, as i have nfi:
Specifications:
Year: 1986 - 1991
Displacement (cc): 1456
Horsepower: 113 @ 5600
Torque (ft-lbs): 127 @ 4400
Bore (mm): 73
Stroke (mm): 87
Compression Ratio: 8.0:1
Vavles per Cylinder: 3
Valve Angle:
Cam Design: SOHC
Ignition System: Distributor
Spark Plug Gap: .044"
Fuel System: Fuel Injected, excess fuel return
Cars Used In: Corsa GP Turbo, Corolla II
General Info:
The beefed up version of the 3E-E, the 3E-TE again is very similar to the 3E-E with the exception that it is turbocharged. This update necessitated a new exhaust manifold, stronger connecting rods, lower compression pistons, and larger injectors. There is not much known about this engine as it was only sold overseas. It is assumed the valve stem seals will go after 100,000 miles the same as the other 3Es.
Similar / Interchangable Parts:
Valvetrain: 3E, 3E-E
Block: 3E, 3E-E
Crankshaft: 3E, 3E-E
Connecting Rods: 3E (downgrade), 1st gen 5E-FE (downgrade), 2nd gen 5E-FE (1995-1996, downgrade), 2nd gen 5E-FE (1997+ downgrade), 5E-FHE (upgrade)
Pistons: 3E (higher compression), 3E-E (higher compression)"
the bit i highlighted, seems true to these, from every thread i came across...this has just gone over the 100k mark then i am sure they are on the way
yeah mate. still there at random times. today i noticed a few things needed tightening under her, so hopefully its just something like that.
having said that, tho, it did sound frighteningly like a bearing, hey...
At random times :hmm:
If it was an engine bearing, it'd be under certain load conditions wouldn't be random i don't think.
Maybe an oil pressure gauge might be the order of the day.
