October 6, 201214 yr comment_630454 Hello guys. I have a quick question, due to my location we don't have a hell of a lot of parts cars to chose from, but the stuff we do have is usually free, Now I have access to many st and rt142 coronas, some with a disk rear end and some without. I'm wanting to run the disks to kind of match my 4 pot hilux calipers, Autho simply bolting disks onto the standard borgy is hardly worth it, That's where I want to use the corona gear, every thing is slightly bigger and a track increase that I'm happy with, plus I have access to a heap of cars for spare axles and centers, That comes to the question, how far off are the mounts? I know that you can get an RA40 rear end to fit but it puts pressure on bushes ect, I am hand enough to make my own swaybar and panhard mounts if needed, Eventually I will go with a hilux rear end, for now this works as a free upgrade, with more spares than I will possibly need. Any help would be much appreciated Casey Report
October 7, 201213 yr Author comment_630575 Afaik the avante model rt142 are IRS, everything else is live axle, some with disks some without, I'm talking about a csx? St141 or st142 whichever it is with the disk brake borg warner Report
October 7, 201213 yr comment_630607 I would just do the hilux diff straight up, you can get supra rear brakes to bolt on. Report
October 8, 201213 yr Author comment_630856 Either way I go I still need to work out if the trailing arm mounts are the same as I would build a jig and use corona mounts on the hilux diff so I have my. Corolla one to accurately measure off, and a hilux diff seems a little silly with a 4ac just yet Might have to bite the bullet and have a go at throwing it in Report
October 9, 201213 yr comment_630883 Nope, they aren't. And the spring perches are in the wrong place. And the wrong size. And the panhard mount is different. Report
October 9, 201213 yr comment_630897 So do the borg warner discs in st14x Corona's bolt onto a KE70 borg warner? Report
