October 16, 201213 yr comment_631997 ok so I'm after some advice jst got my KE70 82model on the road fully stock wih 3 speed gearbox 1.3 ltr, as yous already know its slow and ive got a AE71 84 model manual thats not road worthy able. but i was thinking of puttin ae71 engine(1.6ltr) and the manual gearbox into my ke70, would this be easy enough with many mods or would parts and stuff woulda i have to change around???? Report
October 16, 201213 yr comment_632000 Things you need to change: Pedal box gear box engine cross member clutch master / slave tail shaft thats the basics. Most of it is bolt in but you'll need to drill holes for a few things. Report
October 17, 201213 yr Author comment_632180 thanksss, and does most of the other shit in enginee bayy go to the ae71 engine all good? Report
October 17, 201213 yr Author comment_632244 would you happen to have any ideas on prices this would cost, since I'm not experienced at the moment to do it myself. Report
October 19, 201213 yr comment_632540 Literally just finished this the other day, I can tell you bout anything you need to know 3 speed gearbox I'm assuming it's an Auto Parts needed 4ac engine from your ae71 with with all rwd mounts and manual starter motor T-50 gearbox with its crossmember (an ae71 t50 crossmember fits fine) Engine Crossmember Pedal bx Clutch master Clutch slave Hard clutch line Manual speedo cable Wiring Loom (theres not actually much there just a bunch of wires coming of the positive battery terminal) Voltage Regulator to go on passenger side strut tower near coil Exhaust from AE71, at least front half cos the exhaust is on the other side of the car. Manual gearshift metal shroud - to secure the rubber boot from moving What you will need to modify to turn stuff into manual goodness. 1. Cut a bigger gear shift hole (a dremelll works awesome $90 from bunnings or you can get a cheap ozito) 2. Get a bit of alloy and make cover for you shifer hole area cos the auto hole is too long down the car. 3. Drill the hole in the firewall for a clutch master 4. Make a jumper cable for your auto shifter start in park circuit, and put between two black wires. 5. Wire the reverse lights - just move the wire over from your other car. 6. Move the coil over to the other side of the car, drill into right strut tower. 7. Hook your manual speedo cable up (do this while your dash is apart with the pedal box install). 8. Ground your motor in a bunch of different places. 9. Drill the metal shroud around the gear shifter to hold the shifter and rubber boot in place. Wiring Probably easiest to transfer the whole loom over from the manual car, way easier and just plug and play theres a great guide to cutting the bigger gear shift hole here on the rollaclub, ke70 auto to manual guid I think it's in the technical section. Edited October 19, 201213 yr by easyvision Report
October 19, 201213 yr comment_632559 Overall that's a great idea, it will change the car completely! Just going to a 4K manual was a lot different, much quicker and direct. Report
October 20, 201213 yr Author comment_632695 thanks heaps easy vision, got a better idea now thankyou Report
