October 25, 201214 yr comment_633488 I'm being given a 4k and a bigport 3k. I'm going to put bigport head and manifolds on the 4k (if in decent condish) seeing i have it. Basically i need to know what things need to be changed to fit in ke10 to keep the standard gearbox? its a daily so id prefer to know what needs to be done before changing. Will the standard 4k flywheel/clutch etc work with the standard ke10 4 speed? Pretty sure thats the only thing that I can think of that may need to be changed. Cheers, Report
October 25, 201214 yr comment_633492 I'm pretty sure the old ke10 gearboxes had a smaller spline clutch kit. No biggy though, just put the original 3k flywheel and clutch kit onto the back of the 4k. Apart from that everything should be fine. You might however just want to swap some of the 3k ancilaries (water pump, thermo housing, alternator etc) to make you're life super easy and they do change slightly. Report
October 25, 201214 yr Author comment_633553 Cool cheers.. its got to be an upgrade from the standard k Report
October 25, 201214 yr comment_633566 I have a KE70 4K, extractors and 5 speed in my KE18 and its great. Not fast but at least you can keep up with traffic! Report
October 25, 201214 yr comment_633569 I also have a 4k and 5sp going into my ke20 (ive also got a spare 4k and big port head i am planning to join together and get it balanced to go in the ke20 at a later date) Report
