November 18, 201214 yr comment_636803 Been looking at upgrades and just wondering if any mr2 stuff fit Report
November 18, 201214 yr comment_636807 The engine will with an ae71 xmember, the rear shocks are a good upgrade for ae86 front struts. I think that's about it. Report
November 18, 201214 yr comment_636808 Supposedly the rear shocks fit in the stock KE70 struts and are shorter than stock. Might make the seats fit. Wheels are the same PCD. Report
November 18, 201214 yr comment_636821 ^Word. SW20 MR2 dampers (front and rear) will fit in AE86 shortened strut tubes. Those are about the only parts that you can easily use off an SW20. AW11s have 4AGEs, and as mentioned they can be used for engine conversions into KE70s. Apparently AW11 dampers can be used in KE70 shortened strut tubes but I've never actually seen it done. AW11 steering wheels could be good? Edited November 18, 201214 yr by rian Report
November 18, 201214 yr comment_636826 Wheels are the same PCD. No they aren't. AW11 and ZZW30 are 4x100, SW20 are 5x114.3 Report
