manual 3tc t3/t4 hybrid weber setup turbos lagging won't hit boost till 4500rmp running 3inch piping blow thru 32/36 weber big fmic running 10psi its very smooth but lacks power off boost and only revs 7000rpm so not as much fun as could be. already posted as pablo escobar but locked my self out
Was it like this when you bought it.. maybe the reason the builder sold it!
Sounds like you need to start from the bottom and check eveything, ignition, compression, mixture ratios... and see if he got the basics right to start with.
