January 29, 201313 yr comment_645409 Can anyone tell me what the difference in length is between a standard 4k fan belt and a 4k belt from a car with a/c and does it have a tensioner? Report
January 29, 201313 yr comment_645421 I think 4Ks have a separate belt for the aircon? Anyway, the standard 4K belt is either 890mm or 875mm (KE55, KE70 had some variations etc). And the aircon belt is either 925mm, 955mm or 980mm (again they're are some variations) but it's wider than the standard fan belt. I've never seen a aircon setup on a K engine so I don't know if they use a tensioner or not. Here is the Bosch drive belt catalogue if you want to look it up: http://www.bosch.com.au/content/language1/downloads/Drive_Belt_Web_Ready.pdf They also have this catalogue at most auto stores, plus they have a neat belt measuring tool if you want to measure your belt accurately. Report
January 29, 201313 yr comment_645436 does it have a tensioner? I've never seen a aircon setup on a K engine so I don't know if they use a tensioner or not. I've got an aircon setup on my 4K, I could take a photo if you'd like? Report
January 29, 201313 yr Author comment_645457 I've got an aircon setup on my 4K, I could take a photo if you'd like? If you don't mind putting a pic up that would be good.I have moved the alternator over to the other side and I need a longer belt to suit. Report
January 29, 201313 yr comment_645468 They also have this catalogue at most auto stores, plus they have a neat belt measuring tool if you want to measure your belt accurately. Yup that belt measuring tool has helped me so much over the years. I usually get a piece of nylon rope, wrap it around the pulleys cut it to length. Then get my local Autobarn to measure, works a charm. Report
January 29, 201313 yr Author comment_645472 Yup that belt measuring tool has helped me so much over the years. I usually get a piece of nylon rope, wrap it around the pulleys cut it to length. Then get my local Autobarn to measure, works a charm. Good idea that one,will try it tomorrow. Report
January 29, 201313 yr comment_645475 Pretty sure most parts suppliers will have one. I know my local bursons, Repco and supercheap auto have them also. So you should be right. Report
