March 24, 201313 yr comment_651174 I keep coming up against the questions Do you want the power steering crossmember or the non power steering? I have no idea i have bought a blacktop 20v for my ke70 and I'm assuming I'm not going to be installing PS into the ke70 anyone help me quickly problem shoot this I've searched a few forums with no clear answer cheers jack Report
March 24, 201313 yr comment_651177 You can just buy a mounting kit from me, I make mounts that bolt the 4a straight on to the ke70 crossmember. No need for AE71/AE86 crossmember or mounts. My kits are $200 for Block mounts, new rubber mounts and a gearbox crossmember. Pm me if keen Report
March 24, 201313 yr comment_651184 Save it for the for sale section Jordan. I think that qualifies as peddling. Report
March 24, 201313 yr Author comment_651185 as an aside the questions still valid if any one could still answer this Report
March 24, 201313 yr comment_651194 If you have no intention running power steering with the assorted pump, pulleys and idlers etc, get a non power steering rack. Far more common and less hassle. If you are running PS, you also need the shorter PS steering arms Edit: I should clarify that the Non PS crossmember does differ a little from the PS crossmember in the rack mounts. Edited March 24, 201313 yr by parrot Report
