Hey guys so my 4age 16v has just gotten back running, It has a bad leak in the extractors due to a snapped stud in the block. It also when it warms up starts to beep at me.
The beeping varies in length when i use the clutch... I'm not to sure why?
Any clues?
Beeping from where, 4AGEs don't beep, unless you have aftermarket engine management?
Do you mean the horn beeps?
Edited by B.L.Z.BUB
More info required! as bubbles sais, there is nothing OEM on a 4age that should beep.
Given it changes when you play with the clutch, perhaps its more of a squeek.....In which case it could be any rotating thing...
But since your clutch makes the noise change, perhaps it is your clutch throw out bearing.
