Project "rust Bucket" Is Here.
Yeah its lookin heaps better mate. I actually sold the car for 800 buks, then bought it back! I really missed that old rust bucket. Heres what it looks like now.
my corolla by k.ivoutin, on Flickr
Edited by Kirill
  • Replies 41
  • Views 81.5k
So the bloke you sold it to didn't care, or did you have to win him over? :hmm:
Well the story is; I got a job working away 4 weeks at a time, I had two cars. A 1995 honda civic, and Project Rust Bucket. So my friend just came back from living in Indonesia for 3 years and was looking for cheap car. I thought well i don't need 2 cars so I sold him the Rust Bucket. Then when I was away I thought how stupid that was. So I got back and we swaped my honda civic for rust bucket. The civic by the way was mechanically perfect and had air con and all luxuries! Haha everyone thought I was mad swapping and good civic for the rust heap. But here I am, and here she is.
Lost that job now too :(
Here is another update for those who care.
The head got a sticky valve so I decided to rebuild the motor.
Double valve springs. New guides, seals.
corolla rebuild by k.ivoutin, on Flickr
Port match to the gasket profile.
Shaved head, not sure how much I told him one mm.
Heres the young apprentice thats been helpin out
cleaned up the starter and contacts inside (brushes are bit worn :/ )
clean the carb and new gaskets etc.
polished venturi and venturi body got rid of casting marks, also took out the choke shaft
hares the carb all cleaned up :)
cleaned up the intake manifild, got rid of casting marks etc smoothed out the bumps
new piston rings will go in soon ( need to borrow a motor hoist) and a new stage 2 cam (waiting on that in the mail)
Guys whats the way to remove the motor? Is it easier to separate the box and then lift motor out or wiggle to motor out and support the gearbox with a jack or remove motor and gearbox at the same time.
Last few days I managed to take out the motor, replaced piston rings and gave the bores a hone. replaced con rod caps. I found that 3 out of 4 pistons had cracked rings!
Untitled by k.ivoutin, on Flickr
I was surprised how good the original pistons were, i just cleaned them up a little with wire brush and they were good to go again!
New rings by GRANT (usa) don't know if they are any good or what but they were only 30 buks!
Fitted new bearings
putting pistons back in
Stock cam and 266 duration from Kelford side by side
Box says 2k and 3K, fitted anyways seems to be ok
Black ninja goin back in :P
In the car and head back on
Your doing a fantastic job! Keep up the good work! You wont want to sell it after all the work you have done,
cheers!
well got everything in. Car is running ok, I got about 10 degrees advance on the dizzy. Pulls really hard from about 2000 rpm but doesnt wanna run below that. I'm pretty sure its carby. I think I will give it a celan again tomorow.
And here is a video of it idle (lumpy)
cheers!
Hahaha no one will buy it, Its a piece of rusty crap :)
Rust is part of any old corolla's character!
Little drive around the block :P
