September 5, 201313 yr comment_666234 Alright this might come across badly but meh... I would say that putting 2jz ge or Ecotec in a KE70 is 100 times out of 100 a waste of money. Power to weight of both these engines suck! (1/2jz gte is different) I'll flat out say Ecotec's are not good (maybe for carrying around families with shit fuel economy) I'll also throw out that N/A 2jz suck unless you compare them to 5-6-7M/1G/RB30 etc Motors in my opinion that would be worth while (power vs cost vs potential) pulling apart a KE70 in no particular order. 4AGE 3SGE/GTE(non beams they cost way too much) SR20DET 1UZFE 13B if you could get the motor and box at a good price. 2AZ FE 1/2JZ GTE-turbo RBs as well LS Edited September 5, 201313 yr by It's_AUDM_Yo Report
September 5, 201313 yr comment_666235 If you're looking to bomb up a second motor rather than the one in the car, get yourself a 5K or 7K as a base. Even a stock 5K will give you at least a 20% increase in usable power & torque - i.e. a very noticeable improvement, plus maybe that again by the time you fit extractors and 1 3/4" exhaust, skim the head, grind a cam and improve carburetion. A stock 7K has nearly 50% more power than a stock 4K. Build it on an engine stand, budget for a bit over 2 grand, drive your car in the meantime and then slip it in over a long weekend. It'll buzz like a rotary and do static one-wheel skids on dry bitumen. Good times! And for the record, my dream engine conversion (weighing up cost/power/potential) would be a 2.7litre Hilux 3RZ and W56 combo. Naturally aspirated would be a kick-arse street car. Turboed and tubbed I'd go racing the X275 boys. Edited September 5, 201313 yr by Mechanical Sympathy Report
September 5, 201313 yr Author comment_666288 Yeah well the idea only popped into my head because I found a 2jz On gumtree for $400, so rebuild was the idea... But a 4k would probably be better, stick original and be different by keeping the original motor aha, already has 8" deep dishes On her so rins are set, suspension would probably be next then... While I'm here, anyone got any tips on sticking that black bit back on the choke? I have to pull the choke with pliers on the cold mornings otherwise... Thanks Report
September 5, 201313 yr comment_666292 Its held on with an allen head grub screw on the side. If its missing that you might need to go to a wrecker and pocket another knob. Id assume plenty of old toyotas would use the same knob. Heh heh heh, knob. Edited September 5, 201313 yr by B.L.Z.BUB Report
September 5, 201313 yr Author comment_666295 Yeah thanks for that, I see there is a spot for some sort of screw or something, but I tried the old araldite and that didn't seem to last one pull on the knob... Cheers Report
September 6, 201313 yr comment_666304 Yeah araldite won't cut it. You'll need a good superglue/epoxy. Or another knob. Report
September 16, 201313 yr Author comment_667170 Let it be known for future readers of this thread, home brand superglue is perfectly fine for fixing your choke knob with... No need with a name brand the cheap crap works just fine Report
