Haltech E6X 4Age Silvertop Map ??
gt500biatch
:offtopic: How are you talking to the E6X ? Do you have an old computer with XP still loaded ?
I keep thinking about older Haltech's, but the info I've seen says they all work thru a DOS interface ?
anything pre E6X runs on DOS, E6X and later run on windows.
from haltech website regarding e6x ecu
Please note: This Haltech program is designed to work with early DOS Operating Systems.
In some cases it may work with Win95 or Win98 but if you still have problems communicating
with the ECU you will need to do the following.
Reboot the PC, just as you see text appear on the screen press the F8 key. If caught in time you will see on the screen a bunch of prompts.
Select “Startup in MSDOS mode”, once done you can run the Software.
