Project Sprinter Posted January 28, 2014 Report Share Posted January 28, 2014 Can anybody confirm that the K40 gearbox was the only manual box used in the KE17's imported into Australia? Is this also the same box found in AMI built KE10's? Did they change the box for KE11's? Appreciate any advice that can be given. Thanks. Quote Link to comment Share on other sites More sharing options...
camerondownunder88 Posted January 28, 2014 Report Share Posted January 28, 2014 Hi, KE1X cars only came out with a K40. Have the shifter right up high on the extension housing. Ratios were the same. Cameron Quote Link to comment Share on other sites More sharing options...
parrot Posted January 28, 2014 Report Share Posted January 28, 2014 Pre 6903 is a different part number for the whole transmission for both KE10/15........ Why? The master catalog (printed Nov 72) says the Counter Gear shaft 33411-19015 is common to KE1x & KE2x. However I also have an English language part book (printed Sept 69) for the KE11 series and a JDM book for KE17 which says the countershaft is 33411-12010. A quick google of 33411-12010 tells me via various suspiciously similar US based part sites, that 33411-19015 replaced 33411-12010. So if they are correct, likely you could cannibalize a KE2x K40 for the counter shaft Quote Link to comment Share on other sites More sharing options...
Project Sprinter Posted January 29, 2014 Author Report Share Posted January 29, 2014 Parrot if I can cannibalize the KE2x gearbox - is the gear box with the selector to the aft end? or is it still further up like the KE10/17 gearbox? Quote Link to comment Share on other sites More sharing options...
parrot Posted January 29, 2014 Report Share Posted January 29, 2014 Sorry Gary. I'm going purely from the exploded part diagrams. Assuming from Terryo's post you are after the countershaft, you should be able to use the KE20 part in your KE1x box. Swapping the entire box in is a different issue I can't comment on. Quote Link to comment Share on other sites More sharing options...
Project Sprinter Posted January 31, 2014 Author Report Share Posted January 31, 2014 Thanks Parrot, most appreciated. I can take a look at the KE20 box I have in the garage and see if we get the countershaft married-up. regards, Gary Quote Link to comment Share on other sites More sharing options...
Andy43 Posted February 3, 2014 Report Share Posted February 3, 2014 There are some odd boxes out there, tailshaft spline is different and one bellhousing bolt is located in a different spot. Quote Link to comment Share on other sites More sharing options...
Project Sprinter Posted February 13, 2014 Author Report Share Posted February 13, 2014 Thanks Andy - sorry for he delayed response. We've found this along the way too! Quote Link to comment Share on other sites More sharing options...
