#QLDke10# Posted April 14, 2014 Report Share Posted April 14, 2014 Hi Guys, So i have been posting lots of random questions and i thought i would just start a build thread so i have a central place to find info and share the build. Thanks to Altezza and a few others who have been super helpful so far. I found a 67 rolling shell which had been sprayed and was relatively rust free on fleabay and it had been sitting in this guys shed for 7 years since the work was done. He had cut out the dash and widened the tunnel to take a sr20 and then run out of cash. Plans are just to get it back on the road and then start getting things together to start from scratch (want it to be Matt black rather than purple) So anyway since i have had it is have done the below. Drove to bundaberg and cut the dash out of a rusting away car - also salvaged front seats Found a 4k which i have now started to strip and have everything out of except the crank (can't get the bolt off so any suggestions?) Sourced a k50 in really nice knick - thanks Clapped out for throwing in the free clutch Got twin 1 1/2 SU's and a lynx manifold (yet to mate the two together) Should have rear seats and all cards shipping from Melbourne this week hopefully. Pulled the rollcage out (I'm too tall to have the drivers seat where i need it and still pass engineering) I work about 80 hours a week so progress might be slow but i do have a good 10 day stretch to get some things moving and I'm planning on jacking it up and seeing what running gear i have, think it might have ke50 front struts so might post some pictures see if anyone can identify. Anyway here are some of the pics so far and ill post more as i get to things. Quote Link to comment Share on other sites More sharing options...
Feral4K Posted April 14, 2014 Report Share Posted April 14, 2014 WELL if it isnt the original FERAL4K I built and painted this car twenty odd years ago i reckon! small world... Quote Link to comment Share on other sites More sharing options...
#QLDke10# Posted April 14, 2014 Author Report Share Posted April 14, 2014 So you chopped the dash out? Sacrilege! Quote Link to comment Share on other sites More sharing options...
Feral4K Posted April 14, 2014 Report Share Posted April 14, 2014 Nope i didnt bastardise it was 4k powered hence the name, with white leather interior. kid we sold it to chopped it all up, last i heard it was rotary powered with f@#kin ugly chrome 17s on it good luck with it bro. Quote Link to comment Share on other sites More sharing options...
#QLDke10# Posted April 14, 2014 Author Report Share Posted April 14, 2014 Well if it makes it any better I'm taking it back to as original rolla powered classic goodness as I can Quote Link to comment Share on other sites More sharing options...
Feral4K Posted April 14, 2014 Report Share Posted April 14, 2014 Love your work son giz a call if you need a serious k series for it! check out the feral 4k build on here and youll see were pretty into em! also paint color was mixed by protec paints under the code pull yourself purple lol, or a cadbury violet crumble wrapper! interior was done by precise trimming on the gold coast, and the engine was all mine... i was so tempted to buy it back when i seen it on ebay... Quote Link to comment Share on other sites More sharing options...
Guest pmp16 Posted April 14, 2014 Report Share Posted April 14, 2014 Wow alot of work ahead.. good work Quote Link to comment Share on other sites More sharing options...
#QLDke10# Posted April 15, 2014 Author Report Share Posted April 15, 2014 Thanks Feral, Your not in Brisbane by any chance are you? would love some tips on making a quick engine thats good cruising around in without spending ridiculous cash and i am stripping the 4k now and about to start looking at what to put on and in it. PM me if you have any suggestions on people, parts etc i should be talking to and looking for. Cheers Paul Quote Link to comment Share on other sites More sharing options...
Birksy Posted April 15, 2014 Report Share Posted April 15, 2014 I was looking at buying this! Good to see its gone to a good home. When you finish it and I finish my ke11 we will have to go for a cruise! Quote Link to comment Share on other sites More sharing options...
Feral4K Posted April 16, 2014 Report Share Posted April 16, 2014 Go with the 4k, theyll rev harder than the 5k and put up with a lot of abuse! Go basic reco on what youve already got, rings and bearings, rollmaster double row timing chain kit, and modify the oil pump, new waterpump n gaskets etc, thats all for the bottom end!For camshaft grinding try kelford cams in nerang go for a good bit of duration to get the engine revving to around 7k as thatll be plenty without balancing rod bolts etc, 3k bigport cyl head (welsh plug type) if ya can find one lol, double valve springs and a bit of a shave to bump up the compression, run your manifold and su carbs a nice set of tuned length extractors and electronic dizzy conversion. Should be a fun little critter then, ps build it yourself with a workshop manual its like meccano when you were a kiddie..... hope this helps. Quote Link to comment Share on other sites More sharing options...
Guest pmp16 Posted April 17, 2014 Report Share Posted April 17, 2014 5k performance 10x better than 4k and they still like reving just as much Quote Link to comment Share on other sites More sharing options...
#QLDke10# Posted April 19, 2014 Author Report Share Posted April 19, 2014 Ok so new direction on the build and thought I would update, I got the 4k apart and it was very roached. I worked out after rebore, new pistons and balancing crank I would be better off sourcing a new engine to work with. My love of shiney objects got the best of me and I now have in my hot little hands a factory fresh 5k and 3k big port head which is will build up to put in the car. So when this little beast is on the road it will have 0 ks on the clock which will make it unique and kinda cool. New dilemma today though, while stripping the floors I found a couple of small rust patches and also the job done on the tunnel was pretty poor so I'm going to need to put a bit more into the body than originally planned but that's ok cause I want it done right while it's all in bits. So anyone know a good fabricator / panel and paint place near east brissy? Quote Link to comment Share on other sites More sharing options...
Feral4K Posted April 19, 2014 Report Share Posted April 19, 2014 ill be keepin an eye on this one! Quote Link to comment Share on other sites More sharing options...
Ham Posted April 25, 2014 Report Share Posted April 25, 2014 Nice mate, be keen to see how it comes together for you. What are you doin with the cage? Quote Link to comment Share on other sites More sharing options...
#QLDke10# Posted April 25, 2014 Author Report Share Posted April 25, 2014 Hey ham Probably going to sell it, pm if your after it. Quote Link to comment Share on other sites More sharing options...
