3K Hot Box Gasket
They only usually come with either a VRS kit or a full gasket set, i might have one laying around, i'll go have a look,
cheers!
Thanks for the offer but all sorted now. Found out that repco sell small sheets of the gasket material. don't know why they didnt tell me that in the first place.
cheers.
cheers.
I highly doubt it would be suitable for an exhaust gasket though! I've bought one through Bursons before. Did you also consider just getting one from Toyota?
Hi Taz. The small sheet I bought looks to be made of the same material as exhaust gasket. 100mm x 150mm. From memory I think it should be big enough.
But can it take the heat?
I don't know. As I said, its 'looks' to be made of the same material as the exhaust like on the 3k. Is there something I'm missing? This is it after I cut it.
That is what you want. Shouldn't have a problem.
Edited by GJM85
