Door Light Switches
I was looking for some replacement switches for the door lights on my ke35 and came across these, which were perfect.
They're a grounded 12v switch which plugged in and screwed in to the existing cable and hole.
The car shops had nothing suitable and I found them at an electronics shop.
They came from Altronics in Perth. item number S 5145 $2.45each
Edited by peterd
Hi Peter,
Yep ! Have used the Altronics one, and they work well. On another Corolla I had, (that's since died, and gone to that great garage in the sky), I even used an all "plastic" fridge door switch, which has the switch contacts sealed. It had two spade type terminals on the back. Worked great.
Haven't quite worked out where to fit a switch in the boot, to turn on a light there, everytime the boot lid is opened. Any ideas ?
Cheers Banjo
Edited by Banjo
Banjo, where did the fridge ones come from? Would be great in my patrol, which earth's the pin out every time I do water crossings lol.
And Cheers peterd for sharing the info on the pin switches to match oem.
Cheers, Andy
