B.L.Z.BUB Posted November 15, 2014 Report Posted November 15, 2014 I really wanted to be able to switch my SC on easily, reaching for the switch on the dash was getting tedious. I also wanted it steering wheel mounted for thumb operation. So I went to Jaycar and got some coiled cable and a temporary on button. Found an old fender mirror thing which I bent and cut into kind what I wanted. Tested to see how the button would fit. Contact adhesive and cheap black vinyl. Quote
B.L.Z.BUB Posted November 15, 2014 Author Report Posted November 15, 2014 (edited) I didnt end up running the washer. Added some velcro so its removable. Wired and mounted it. All the button is doing is completing the circuit from the AFM to the ECU, so the ECU and SC relay are still doing all the work. Edited November 15, 2014 by B.L.Z.BUB Quote
B.L.Z.BUB Posted November 15, 2014 Author Report Posted November 15, 2014 (edited) Shitty video of it in action. Just took it for a spin, works great. The spiral cord is a bit annoyign and I considered using the horn circuit but then the horn is useless. Ah well it was a fun experiment. :) Edited November 15, 2014 by B.L.Z.BUB Quote
rian Posted November 15, 2014 Report Posted November 15, 2014 (edited) Your spiral cord has to hang low for ultimate gangster points. Edited November 15, 2014 by rian Quote
rian Posted November 15, 2014 Report Posted November 15, 2014 Also, how do hold the button down when you're going around corners? You should totes put in a turbo light like in Knight Rider. Quote
B.L.Z.BUB Posted November 15, 2014 Author Report Posted November 15, 2014 It's only meant to be for quick bursts off the line or overtaking. If I want it on for twisty stuff I have the switch on the dash I can toggle instead. Quote
rian Posted November 15, 2014 Report Posted November 15, 2014 ohhhhh it's in parallel, that's pretty cool. Quote
B.L.Z.BUB Posted November 15, 2014 Author Report Posted November 15, 2014 Yeah bro. Pimp'd that shit. Quote
Super Jamie Posted November 18, 2014 Report Posted November 18, 2014 I like your stereo. And your sunglasses golder. And your gauge holder. This is cool. Where did you get the vinyl? Quote
altezzaclub Posted November 18, 2014 Report Posted November 18, 2014 Why not have it under the accelerator? Just hit it hard enough and it comes straight on. Quote
B.L.Z.BUB Posted November 18, 2014 Author Report Posted November 18, 2014 Because I don't want to toggle it every time I accelerate. I have a dash switch that can make that happen. Quote
B.L.Z.BUB Posted November 18, 2014 Author Report Posted November 18, 2014 Where did you get the vinyl? Spotlight, its like $15/m about 1400mm wide. Quote
