January 12, 201511 yr comment_692957 Been looking around for a while now but can't seem to find any info on the offset of the stock wheels. Also, tyre size too. My ones have 185/60's on them but I've gathered they're not the right size as the speedo is out and the clearance between the front strut and tyre is like 1mm. Just needed so I can start looking at what wheels will fit. Cheers. Report
January 12, 201511 yr Author comment_692961 Look down 3 posts After rim specs and factory tyre specs for a ke35, not tyres for a ke30. Rim width's and offsets are vital for finding what'll fit. Report
January 12, 201511 yr comment_692962 They're the same between ke30 and ke35.. Do you have the factory rims on your car? If so the width and offset are printed on them. Report
January 12, 201511 yr Author comment_692964 They're the same between ke30 and ke35.. Do you have the factory rims on your car? If so the width and offset are printed on them. I do have the factory rims but the paint is so heavy it's unreadable. I can only gather the obvious which is 13". Report
January 12, 201511 yr comment_692965 The tyre size and rim width is in that thread. if you have stock wheels you can measure the offset yourself Report
January 12, 201511 yr Author comment_692966 The tyre size and rim width is in that thread. if you have stock wheels you can measure the offset yourself I was just hoping for a simple straight answer but if no one knows (surprisingly) I'll just measure cheers. Report
January 12, 201511 yr comment_692967 I made a thread asking about stock wheel sizes for a ke30. Theres a good chance a 30 would share sizes with a 35 Report
