February 14, 201511 yr comment_694166 KE30. Does anyone know of a decent suspension specialist on the Southside of Brisbane? After taking it to 2 differant places for allignment, my car handles worse then it was before. Report
February 15, 201511 yr comment_694192 Most places will only adjust toe for wheel alignment. ke series usually have adjustable caster too. try a place with a laser sight wheel alignment machine (hunter, visualiner, hoffman etc) i found the older ones i used weren't hugely accurate. Report
February 15, 201511 yr Author comment_694200 Yeah ive modified the front end so I need someone to 'tune' it. Theres only caster and toe. The only thing thats been done to caster is the last shop adjusted the drivers side to compensate for road slope. They over shot the mark which ive sinse corrected. I can't see how the caster isnt wrong seeing as Ive modified the front and replaced all heavilly worn bush's etc. Ill call Southside Suspension tomorrow as I work down that way. Report
February 15, 201511 yr comment_694217 Go to a place that will give you a before and after report. Also decide on your settings and write them down and give to the guy doing the alignment. Then before you pay compare it to the "after" report.... Edited February 15, 201511 yr by ke70dave Report
