The three inlets into your tank would be 1;fuel line to carby 2 overflow from the filler neck (larger one)3 the line that goes to the charcoal canister.
Well on ke 55 any way.
Not sure about ke30 ,but if its 79 it would be 55 not a 30?and a 3rc engine ??
Make sure your carter pump is low pressure or you will create more problems
rob
