September 10, 201511 yr comment_699998 Ok guys I have a AE71 Panel van and I'm wanting to put a 4A motor in it once again. *Bought it rolling* Will a 4k with 5 speed tail shaft and diff from a wagon meet my 4a with 5 speed to the same length from box to rear wheel arch? and is the diff ratio compatible? Thanks in advance Edited September 15, 201511 yr by MartyJ Report
September 15, 201511 yr comment_700104 A k series tailshaft won't work on a 4age/t50 combo. Diff ratios should be sweet though. You'll also need to check if your diff is a borg warner or an S series as you'll need to get a shaft to suit that too. Report
