Speedway Levin Posted November 19, 2016 Author Report Posted November 19, 2016 I got a all clear code from the ECU for a short time but 1 is back! I'm reading so many old forums most around 2009 to try and help with the problem Quote
ke70dave Posted November 19, 2016 Report Posted November 19, 2016 Unfortunalty alot of valuable info is from back then as that was the hey day of forums. With facebook no knowledge is retained anymore:( Quote
Speedway Levin Posted November 21, 2016 Author Report Posted November 21, 2016 Code 12 which is RPM signal but also related to the ignition circuit I can NOT clear, haven't given up yet Quote
Speedway Levin Posted November 25, 2016 Author Report Posted November 25, 2016 Well Ive cleared the ECU codes, and timing still retarding :( I'm going to be a expert by the time this is sorted Quote
LittleRedSpirit Posted November 25, 2016 Report Posted November 25, 2016 Did you fix the wiring problems that caused the codes, or did you just clear the codes? Quote
