AE92 4AGE fuel pump fuse location
15 hours ago, ke70dave said:
Is it just a standard 4age? If it were me id put an oem sx pump.
Who said anything about it being standard? :)
It's making around 310HP at the crank. A 500HP pump might be overkill, but that's what was put in by the performance shop.
  • Replies 43
  • Views 22.6k
  • That’s the pressure line. The small nut as you call it is like a large brake line fitting, and screws into the body of the larger ‘nut’.  To undo it, hold the larger ‘nut’ with a spanner and undo
  • Ideally empty the tank as it can be surprisingly heavy when manoevering around under the car
  • As you alude to i think most fuel tanks sitting in a yard are going to be rusty too. My mate recently gave life to a 46yr old VERY rusty civic tank with this stuff. I saw the final product and i
Haha true, I like to keep a bit of mystery ;)
Idk, just to see if it will work and that is the problem before I spend any real money on it. I actually have the OEM pump somewhere in a box, so maybe I can swap it out just to test it!
reviving a pump is very difficult. i tried it and failed. when it dies due to no use its usually moisture causing corrosion.. and that is irreversible.
Fair enough. Do you have any guides on how to remove and replace the fuel pump, and is this even something I should attempt myself? I've done a bit of a search online and on this forum and couldn't find a step by step guide anywhere.
no idea. i havent owned an AE haha.
can u get to the pump cover under the back seat?
It’s super easy. My 2 cents, go and pull one out of a car at a pickies wrecker. One, it will be hella cheap, and two, you will know what to do on yours. The hardest bit is swapping the actual pump out of it’s carrier and getting the little insulator rubbers in the right spot, and mounting the pre filter. And that’s not hard.
edit: I should say you can just use one out of an SV21 Camry if your model isn’t there
Edited by parrot
So I attempted it, but I can't actually find where the pump is! It wasn't where I thought it was, which was under the back seat where the access port is and where the wires are going to. What I pulled out was the fuel gauge sending unit, but no pump inside :(
Does anyone know where it's located on an AE92 Corolla? Do I have to drop the fuel tank (please say no)?
Okay so after a bit of digging around, I discovered I do in fact have to drop the tank. After looking at some youtube videos, it doesn't seem too hard. There are 3 fuel lines to disconnect, then the fuel intake hose and then the straps that hold the tank to the car. There is one fuel line I can't disconnect because I'm not sure which nut to unscrew. In my pic there is the nut with the blue arrow and the other larger nut with the red arrow. Which is the one I should be unscrewing? What are these fittings called so maybe I can search online? They are high pressure fittings as far as I can tell. I've attempted to undo both, but without knowing which way to unscrew them or which nut, I'll just damage the line, so I stopped.
To undo it, hold the larger ‘nut’ with a spanner and undo the smaller ‘nut’
Thanks for the info. I had already emptied the tank, so this was my next challenge. It’s a tough nut to crack (pun intended):)
I only had a shift spanner so when I was trying to loosen the nut it slipped and I think I twisted the whole thing. Pretty sure I damaged the pipe inside as now the body of the nut spins somewhat freely and a little bit of fuel dripped out.
Both nuts are like they’re welded together, so tough! Tried lots of WD40.
Just so I’m sure, which way should I be turning the smaller nut? Looking at it from the left in the pic I’ve been turning it anti-clockwise. Is that correct?
I'm going to buy some open end spanners at the end of the week and try again.
I have proper spanners now and still no luck. I guess I keep trying until they crack
