May 17, 200620 yr comment_117926 keep in mind that for any given cam, the power range will start and finish about 1000 rpms lower on a 5k, as compared to a 4k. Report
May 17, 200620 yr comment_117937 mind the camtech cams friend has one turn up without the hole in it for the pully locating dowl, to fix it the camtech guy held it in one hand and bored a hole in it with a cordless drill, got to wonder how exact they are! Report
May 18, 200620 yr Author comment_118194 well i ran a wanted add in the quokka for standard engine parts. and i have a few irons in the fire, camshaft enginring has two jigs , one a stage two mild grind or a stage four WILD grind based on the serria cosworth. maybe i just get both :D Report
May 19, 200620 yr comment_118234 well i ran a wanted add in the quokka for standard engine parts. and i have a few irons in the fire, camshaft enginring has two jigs , one a stage two mild grind or a stage four WILD grind based on the serria cosworth. maybe i just get both :D Same cam as i have in mine now Chris,the wild one, A3 grind,the A2 grind is a little milder,which i also have here. Edited May 19, 200620 yr by madrolla68 Report
May 19, 200620 yr comment_118330 have you got some specs for those cams? would be interested to add them to the dyno2000 camfiles i have. Report
May 19, 200620 yr comment_118342 have you got some specs for those cams? would be interested to add them to the dyno2000 camfiles i have. Yeah mate ill grab them for you tomorrow,I'm off for a championship go-kart race tonight so a bit busy. Report
May 20, 200620 yr comment_118440 have you got some specs for those cams? would be interested to add them to the dyno2000 camfiles i have. Ok man here you go. A2 40/76 296 degrees duration. 220" Lift at the cam. Tappet clearance IN 0.020" EX 0.022" A3 50/86 316 degrees duration. 240" Lift at the cam. Tappet clearance IN 0.020" EX 0.024" Report
May 20, 200620 yr comment_118551 thanks. geez, they are not very generous in the lift department. how does it go in your engine? Edited May 20, 200620 yr by Felix Report
May 20, 200620 yr comment_118597 thanks. geez, they are not very generous in the lift department. how does it go in your engine? Yeah good,don't want to use really big lift in these engines i find,just what ive found anyway. Report
May 21, 200620 yr comment_118709 the bigger grind you have listed has only 0.360 thou (gross) at the valve.... i sort of think they should have bumped up the lift for the translation over to k series. a 5k just doesn't have anywhere near the valve curtain area of a cosworth 4 valve head. anyway, hope it works for you. :) Edited May 21, 200620 yr by Felix Report
May 21, 200620 yr comment_118733 the bigger grind you have listed has only 0.360 thou (gross) at the valve.... i sort of think they should have bumped up the lift for the translation over to k series. a 5k just doesn't have anywhere near the valve curtain area of a cosworth 4 valve head. anyway, hope it works for you. :) Yeah i think youre right ,which is why i am using the bigger valve area. Report
May 21, 200620 yr comment_118736 fair enough, probably help even things up. what type of valves have you got in there? sizes? compression ratio? Report
May 21, 200620 yr Author comment_118737 so will that make much diffrents with my standard head? Report
May 21, 200620 yr comment_118738 fair enough, probably help even things up. what type of valves have you got in there? sizes? compression ratio? Not sure on the exact size but there is like .030" between the two valves,the comp ratio is only 10.5 to one. Have you run the cam on the DYNO2000 program Vs other cams yet like the CAMTECH 609. Report
May 21, 200620 yr comment_118739 so will that make much diffrents with my standard head? What you talkin bout chris??????/ Report
