Can I Get New Cams
  • Replies 45
  • Views 54.5k
yep. just trying to get a better idea of your combo.
Is it any good that program and if so where can i get a copy .
Ill measure the valve sizes tomorrow for ya,ive got some old ones aout of the 3K engine that dropped a valve
chrisandliz.... you are talking about the milder of the two cosworth grinds that madrolla has?
personally i would recommend a tighe 113. 25/65 270 degs duration 0.400" thou lift (gross) at the valve. works great on a pretty much standard setup to a pretty full on combo. great street cam.
sorry, the lift on the cam, if i still have standard valves
Yeah but i think the smaller duration would be better for you,seeing as you want driveability.
I just want HP and HEAPS of it.
umm umm umm, maybe i better learn more about cams first, :) sorry a bit clue less
well i just have to try and see
Just have to select the one that best suits your needs and engine spec's
These are the specs for my cam - Wade 169
the specs are:
Lift (at lobe) - 0.269"
Ex opens - 75deg closes 36deg
Inlet opens - 41deg closes 70deg
sorry to change the topic abit, what base timing with work best for mild cam?? :)
I would suggest around 8 or 10 depending on what the total is on the distributor.
the specs are:
how much gross lift at the valve does this equal to?
Times it by 1.5
(so if i get this) the valvue will move about 10mm, if thats so, what is the standard cams lift?
Whatever the lift is at the cam ,times it by 1.5 and then subtract the tappet clearance and you have the valve lift.
Not sure what the standard valve lift is.
10mm valve lift is .400",not bad at all
