Redwarf Posted May 22, 2006 Report Share Posted May 22, 2006 It's not that bad, I'd say it just get's a bit fiddly on the install. Quote Link to comment Share on other sites More sharing options...
Rolla__Boy Posted May 22, 2006 Report Share Posted May 22, 2006 I have changed 2 KE30's from auto to manual...and the pedal box is not all that hard, just fiddly and annoying like you said. I found the most difficult bit was actually getting the pedal box to clear everything as I took it out...and worse making it fit back in. And I also HATE pulling auto's off engines...the stupid convertor bolts are almost always impossible to get out...it's a pain in the ass Quote Link to comment Share on other sites More sharing options...
chrisandliz[RL] Posted May 22, 2006 Author Report Share Posted May 22, 2006 do you think i could steel all the bits i need for a ke70? Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted May 23, 2006 Report Share Posted May 23, 2006 I have changed 2 KE30's from auto to manual...and the pedal box is not all that hard, just fiddly and annoying like you said. I found the most difficult bit was actually getting the pedal box to clear everything as I took it out...and worse making it fit back in. And I also HATE pulling auto's off engines...the stupid convertor bolts are almost always impossible to get out...it's a pain in the ass you mean the 10mm that hold the torque converter to the flex plate?? did this the other day and was thinging how the hell to you get a spanner on that well enough to get them out......then realised on the bottom of the backing plate there is a little cover that pops out so you can use a ratchet. did you not find this cover?? Quote Link to comment Share on other sites More sharing options...
chrisandliz[RL] Posted May 23, 2006 Author Report Share Posted May 23, 2006 Uhm NO :) why not, i was going to use a 4k and gear box and hack out all the other bits i need. is the clutch pedel to big?? TELL ME PLEASE, WHAT IS HAPPENING :) does any one have a picture of a clutch pedel??? Quote Link to comment Share on other sites More sharing options...
Rolla__Boy Posted May 23, 2006 Report Share Posted May 23, 2006 you mean the 10mm that hold the torque converter to the flex plate??did this the other day and was thinging how the hell to you get a spanner on that well enough to get them out......then realised on the bottom of the backing plate there is a little cover that pops out so you can use a ratchet. did you not find this cover?? Yeah I know where the cover is...Most of the bolts I have had to remove, have either been rusted, or so so so tight I couldn't get them undone. why not, i was going to use a 4k and gear box and hack out all the other bits i need. is the clutch pedel to big?? TELL ME PLEASE, WHAT IS HAPPENING :) does any one have a picture of a clutch pedel??? Are you suggesting you want to try and use KE70 parts for a KE10? Quote Link to comment Share on other sites More sharing options...
chrisandliz[RL] Posted May 23, 2006 Author Report Share Posted May 23, 2006 why not, if i can, cos i have a ke 70 to steel from. "toyota motor corpation" manual tells me that the engines and gearbox are conpatable. Quote Link to comment Share on other sites More sharing options...
Rolla__Boy Posted May 23, 2006 Report Share Posted May 23, 2006 You want to use the pedal box though, which if you have a look at where and how they both bolt in, you will see that they are nothing like each other, and you have zero chance of bolting a KE70 one in. Quote Link to comment Share on other sites More sharing options...
Redwarf Posted May 23, 2006 Report Share Posted May 23, 2006 once I've charged my camera batteries, I'll take a photo..... Quote Link to comment Share on other sites More sharing options...
thomo Posted May 23, 2006 Report Share Posted May 23, 2006 sort of related subject, when your pulling an auto out you can leave the converter bolted up, yank the box then undo the bolts on the ring gear, just expect to drop some oil. just don't try to put it in seperatly or youll stuff the pump in the box Quote Link to comment Share on other sites More sharing options...
thomo Posted May 23, 2006 Report Share Posted May 23, 2006 and do you need to change the tail shaft yoke to early ke 30? can't remember the ke20 spline Quote Link to comment Share on other sites More sharing options...
