May 22, 200620 yr comment_118903 It's not that bad, I'd say it just get's a bit fiddly on the install. Report
May 22, 200620 yr comment_118917 I have changed 2 KE30's from auto to manual...and the pedal box is not all that hard, just fiddly and annoying like you said. I found the most difficult bit was actually getting the pedal box to clear everything as I took it out...and worse making it fit back in. And I also HATE pulling auto's off engines...the stupid convertor bolts are almost always impossible to get out...it's a pain in the ass Report
May 22, 200620 yr Author comment_119001 do you think i could steel all the bits i need for a ke70? Report
May 23, 200620 yr comment_119029 I have changed 2 KE30's from auto to manual...and the pedal box is not all that hard, just fiddly and annoying like you said. I found the most difficult bit was actually getting the pedal box to clear everything as I took it out...and worse making it fit back in. And I also HATE pulling auto's off engines...the stupid convertor bolts are almost always impossible to get out...it's a pain in the ass you mean the 10mm that hold the torque converter to the flex plate?? did this the other day and was thinging how the hell to you get a spanner on that well enough to get them out......then realised on the bottom of the backing plate there is a little cover that pops out so you can use a ratchet. did you not find this cover?? Report
May 23, 200620 yr Author comment_119069 Uhm NO :) why not, i was going to use a 4k and gear box and hack out all the other bits i need. is the clutch pedel to big?? TELL ME PLEASE, WHAT IS HAPPENING :) does any one have a picture of a clutch pedel??? Report
May 23, 200620 yr comment_119070 you mean the 10mm that hold the torque converter to the flex plate??did this the other day and was thinging how the hell to you get a spanner on that well enough to get them out......then realised on the bottom of the backing plate there is a little cover that pops out so you can use a ratchet. did you not find this cover?? Yeah I know where the cover is...Most of the bolts I have had to remove, have either been rusted, or so so so tight I couldn't get them undone. why not, i was going to use a 4k and gear box and hack out all the other bits i need. is the clutch pedel to big?? TELL ME PLEASE, WHAT IS HAPPENING :) does any one have a picture of a clutch pedel??? Are you suggesting you want to try and use KE70 parts for a KE10? Report
May 23, 200620 yr Author comment_119071 why not, if i can, cos i have a ke 70 to steel from. "toyota motor corpation" manual tells me that the engines and gearbox are conpatable. Report
May 23, 200620 yr comment_119075 You want to use the pedal box though, which if you have a look at where and how they both bolt in, you will see that they are nothing like each other, and you have zero chance of bolting a KE70 one in. Report
May 23, 200620 yr comment_119083 once I've charged my camera batteries, I'll take a photo..... Report
May 23, 200620 yr comment_119154 sort of related subject, when your pulling an auto out you can leave the converter bolted up, yank the box then undo the bolts on the ring gear, just expect to drop some oil. just don't try to put it in seperatly or youll stuff the pump in the box Report
May 23, 200620 yr comment_119158 and do you need to change the tail shaft yoke to early ke 30? can't remember the ke20 spline Report
