:P -Hey, just wondering if anyone with a KE30/KE55 and all similar corollas have the same problem as me or know of what it could be?? Okay, it happend last winter and again as it started to be cold its happening again. :D
So i have to leave for work at like 3:00am/3:30am and when I attempt to start the car it wont start. :S Its like it tries to kick over but stalls straight way. I try to punp the accelorator while trying to start and if i'm luck on the third or fourth go it may start.
I'm just interested if anyone knows what the problem may be or if anyone has encountered it themselves?? :sad:
thanks heaps,
Jon.
All i do is pump my accelerator once let it fire, it then stalls so i pump it twice it will fire and then i give it a few quick half throttle pumps to keep the fuel squirting and its right as rain, give it a go.
:P -I had the same problenm last winter, then when summer rolled around it was fine. Barely had to twist the key. I don't think its the battery??
Jon.
During the day, when i finish work, she starts normally.
I'm usually pumping the accelorator??
I just wanted to see if anyone knew what it could be before i go and pay someone to tell me whats wrong.
thanks,
Jon.
Edited by JiP_01
:P -I know. Cause it all happend last year. There's gotta be something for it to start easier shouldn't there??
Jon.
Guest Brad
Yeah its just cold man. I noticed it too, just pump it twice, turn the key should start and if it sounds like its dying, just give it a couple of pumps and she is jake.
Bradelz
Edited by Brad
:P -Choke, whats that??
Do i really look that sill??
Don't answer that.
Yes, i know about the choke.
Jon.
:P -I do. It is hard to start cause its cold and was hoping that there was something i can do it fix it.
Like i pump it, i use the choke and she stalls the first few goes.
Jon.
Jon.
just a thought (maybe I'm wrong) but my father-in-law said that oil type coils can be afected by the cold. or maybe it's just crap
lol, one of the joys of running an older carbed car.
you can adjust the choke with the fast idle link on the side of the carb. look in a workshop manual for the procedure.
Guest Brad
it's just cold JiP give it some time mine starts on the 2nd go, then it sputters and carrys on, and its fine after it gets warm.
Brad
