pauly Posted June 10, 2006 Author Report Share Posted June 10, 2006 car uses lots of fuel, runs shitty, ummmm thats about it i think Quote Link to comment Share on other sites More sharing options...
Mr Revhead[RL] Posted June 10, 2006 Report Share Posted June 10, 2006 if your knock sensor has been glued, its f@$kED replace it. if it was plugs and leads itll run worse under boost, ie higher revs than below 4k. is the o2 sensor u got compatible? Quote Link to comment Share on other sites More sharing options...
Mr Revhead[RL] Posted June 10, 2006 Report Share Posted June 10, 2006 this is a MAP 4agze? if so ITS YOUR KNOCK SENSOR! GET A NEW ONE!!! get it? if its an AFM one, itl lbe something else as well Quote Link to comment Share on other sites More sharing options...
pauly Posted June 10, 2006 Author Report Share Posted June 10, 2006 its a AFM and do u know how much is a knock sensor is its $250!! um but doesnt knock sensor ONLY effect the engine when it runs over 4grand>>?? oh and do u have MSN? Um o2 sensor is perfect match and not sure what else help,..... Quote Link to comment Share on other sites More sharing options...
TRD ke70 Posted June 10, 2006 Report Share Posted June 10, 2006 Mr Revhead's right, replace the knock sensor. they generally work under 4 grand to control ignition timing, retards the ignition when detenation happens, if the sensor is sending the wrong signal the igniton timing will be being retarded, so it'll be gutless and be using heaps of fuel. also check for airleaks between the AFM and the throttle body this can also cause the engine to drink heaps. Quote Link to comment Share on other sites More sharing options...
Mr Revhead[RL] Posted June 11, 2006 Report Share Posted June 11, 2006 from our brief mn convo (sorry my spare 20v motor arrived :ninja: ) i learned his is an AFM 4agze. if thats the case the knock sensor wont be causing those symptoms, unless the gluing is causeing it to send a f@$ked up signal. i run my AFM 4agze with no knock sensor and while itll only run the base timming and is prob costing power, it actually runs fine. so yeah start looking ofr vacuum leaks etc Quote Link to comment Share on other sites More sharing options...
Jono Posted June 11, 2006 Report Share Posted June 11, 2006 is this car a white one with white wheels? Quote Link to comment Share on other sites More sharing options...
pauly Posted June 11, 2006 Author Report Share Posted June 11, 2006 white with chrome 17's, Quote Link to comment Share on other sites More sharing options...
pauly Posted June 11, 2006 Author Report Share Posted June 11, 2006 what about boost leak? from charger to FMIC to intake?? maybee? Quote Link to comment Share on other sites More sharing options...
pauly Posted June 13, 2006 Author Report Share Posted June 13, 2006 maybee but boost is running normal (just found that number 4 lead doesnt click on properly maybee thats a problem) pauly Quote Link to comment Share on other sites More sharing options...
pauly Posted June 13, 2006 Author Report Share Posted June 13, 2006 yep was leads and plugs :thumbsup: all goin nice but I'm pretty sure there is a boost leak as its only gett MAX 5psi and constant 3psi?? Quote Link to comment Share on other sites More sharing options...
