4agze
pauly
Mr Revhead's right, replace the knock sensor.
they generally work under 4 grand to control ignition timing, retards the ignition when detenation happens, if the sensor is sending the wrong signal the igniton timing will be being retarded, so it'll be gutless and be using heaps of fuel.
also check for airleaks between the AFM and the throttle body this can also cause the engine to drink heaps.
from our brief mn convo (sorry my spare 20v motor arrived :ninja: ) i learned his is an AFM 4agze.
if thats the case the knock sensor wont be causing those symptoms, unless the gluing is causeing it to send a f@$ked up signal. i run my AFM 4agze with no knock sensor and while itll only run the base timming and is prob costing power, it actually runs fine.
so yeah start looking ofr vacuum leaks etc
