March 15, 20242 yr comment_736532 So i have a corolla ke30 2 door with a 4age engine but there is no aircon components for it, would it be better if i should just find the components for the 4age aircon or just get an electric aircon kit and if so any recommendations? Report
March 15, 20242 yr comment_736534 There are a lot of parts to hunt down for the AE86 aircon and they are old, worn out and expensive. If you can find them. But the upsurge in AE86 prices has people looking to restore to factory. If there are modern alternatives in a complete kit you can retrofit I would be doing that. What has your research thrown up so far. Report
March 15, 20242 yr comment_736535 Agree with Pete completely. Find an aftermarket compressor, of comparable size. Big task, but has been done before. Suggest you search on the 4AGE website forums, as there are a number of suggestions there. Whatever way you go, you are probably still going to need the 4AGE AC adapter bracket, which ever compressor setup, You finally decide upon. https://justjdmimports.com/product/toyota-ae86-4ag-16v-new-non-pwr-str-a-c-bracket/ Good luck ! P.S. Did you save up, for the imported short shifter ? Cheers Banjo Edited March 15, 20242 yr by Banjo Report
March 15, 20242 yr comment_736536 Did your KE30 have aircon to start with?? The plastic vents under the dash are quite different between having it or not, and there's quite a bit of work to do if you have to find those parts and pull out the dash to fit them. Report
March 16, 20242 yr Author comment_736545 near to getting the short throw shifter and thanks for the info will definitely search more on that forum thanks Banjo Report
March 16, 20242 yr Author comment_736546 yeah my corolla did use to have aircon in it but previous owner took it out to hear more of the itb's, dash still has the original vents Report
March 16, 20242 yr Author comment_736547 oh and any of you could recommend me any wiper motor for my corolla cause my old one failed on me not sure if it's electrical problems or just the wiper motor stopped midway through a heavy rain Report
March 16, 20242 yr Author comment_736548 I've seen some that has done it but it's pricey and finding the parts all together still trying to get more information about it if you've got any do let me know parrot Report
