Medicine_Man Posted May 26, 2004 Report Share Posted May 26, 2004 Quote Link to comment Share on other sites More sharing options...
irokin Posted May 26, 2004 Report Share Posted May 26, 2004 Ah yes the good old VCV and the VSV oh and you can't forget the EGR V Quote Link to comment Share on other sites More sharing options...
Super Jamie Posted May 26, 2004 Report Share Posted May 26, 2004 the BVSV and the V S/W do it for me every time, lol ah the memories Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted May 26, 2004 Author Report Share Posted May 26, 2004 Pretty much useless, owing to the fact that legally you can rip it all off, but thought I would post it just for the records.. Quote Link to comment Share on other sites More sharing options...
ke1x Posted May 26, 2004 Report Share Posted May 26, 2004 what's a pollution control? thats why i drive a ke15. pre ADR's Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted May 26, 2004 Author Report Share Posted May 26, 2004 If I'm not mistaken anything pre 1985 doesn't require these emissions hoses as long as it passes the exhaust emissions testing.. Quote Link to comment Share on other sites More sharing options...
irokin Posted May 26, 2004 Report Share Posted May 26, 2004 If I'm not mistaken anything pre 1985 doesn't require these emissions hoses as long as it passes the exhaust emissions testing.. I thought it was a fine of like $2000 per cylinder for modifying the emissions output of a car from the EPA.... Edit...errm...quoted the wrong thing :P Quote Link to comment Share on other sites More sharing options...
ke1x Posted May 26, 2004 Report Share Posted May 26, 2004 i think you will find you would be legally required to meet the ADR requirements of the year of manufacture. think the ADRs started in the early/mid 70's. 1974??? my 73 HQ holden was pre emissions. PCV system only. 75 ke30 ADR plate, but not much in the way of emisions gear. the earlier ke1x series have a simple dump pipe for crankcase emissions. all the blowby is directed down the gearbox tunnel under the car. it's so complex :P haha...sorry, just wanted to try that smiley ! really so long as you do things neatly to pass a visual you should be fine. just make sure anything that needs to be plumbed into the airfilter still is if you change to an aftermarket item. ballbearings work good in vacuum lines. Quote Link to comment Share on other sites More sharing options...
Super Jamie Posted May 26, 2004 Report Share Posted May 26, 2004 ADRs started in 1972 the 72-75? (maybe 78) K emissions system consisted of a pcv plate beneath the carb, pcv valve on the rear of the rocker cover, tube from the middle of the rocker cover to the air cleaner housing, timing cover with crankcase vent, going to another pcv valve bolted to the block, connected to the air cleaner housing, and with a hose to the transmission tunnel whoever told you that it's legal to remove the emissions gear from any car is incorrect. any modifications to emissions need to pass EPA tests to prove the car is equal or better to the original standard. technically it's illegal to have your vac lines blocked up with ball bearings too, or a 3k carb with the 4k stuff bolted to it so it looks like it's original, but who's going to check :P f@$k, it's technically a defect to put a pod on a new(ish) car without an engineering cert in queensland they do roadside emissions tests, much like an RBT for your car. that being said, fook had his gsr put through one of them, with no cat, and it passed so they can't be too strict i've personally found that without a pcv valve and plate, my oil is f@$ked and black within 150 miles. with the pcv system intact (however, chrome filter on middle rocker cover hose, 4k timing cover with no vent) my oil stays cleaner a hell of a lot longer Quote Link to comment Share on other sites More sharing options...
demuire Posted May 26, 2004 Report Share Posted May 26, 2004 Hehe, my engine *had* a VSV on it. But no, I don't have it anymore, my wires just go nowhere... *edit* In QLD pod filters are legal. Not in NSW though, the filter has to be enclosed if I'm not mistaken. Quote Link to comment Share on other sites More sharing options...
irokin Posted May 27, 2004 Report Share Posted May 27, 2004 even the standard element doesnt flow very well...i.e. I'll tune my car with the air filter off for easy access to the mixture screw. Then I put it back on and it wont idle... :dry: Quote Link to comment Share on other sites More sharing options...
Super Jamie Posted May 27, 2004 Report Share Posted May 27, 2004 thats because you're sposed to tune your idle with the air filter on :fuzz: the air moves a heap differently at idle without a filter on, hence the idle characteristics change. the stock element flows fine, just the snorkel housing isn't helping things, hence why i cut mine up :P the idle bits aren't that hard to get to, even in our little ke2x engine bay. it's way too cramped to get a screwdriver in there, i find it's a million times easier to twiddle the mixture and idle speed screws with a 5c coin, i keep a few in my ashtray for this purpose Quote Link to comment Share on other sites More sharing options...
irokin Posted May 27, 2004 Report Share Posted May 27, 2004 the stock element flows fine, just the snorkel housing isn't helping things, hence why i cut mine up well my covers got a few holes drilled in it :P meh dodgy aisans going the way of the bin... Quote Link to comment Share on other sites More sharing options...
ke1x Posted May 27, 2004 Report Share Posted May 27, 2004 well my covers got a few holes drilled in it plus your cold air induction :P Quote Link to comment Share on other sites More sharing options...
Super Jamie Posted May 27, 2004 Report Share Posted May 27, 2004 meh dodgy aisans going the way of the bin... no no give it to me! Quote Link to comment Share on other sites More sharing options...
