Gasket Sealent
Hey i was just wondering what sort of sealent people use when putting the alloy cups around the sparkplugs and other gaskets on the motor as i am having trouble sealing the sparkplug cups. I've used a black silicon sealant which was a waste of time and i've now tried aviation for-a-gasket No. 3 goo no hardening.
Just wondering if there is something on the market that the toyota factory used it was a grey colour
Cheers nathan thanks in advance
Yeah i got those but they still seam to leak passed them i think i need to use a different sealant
No, you just require the correct technology.
Because the Tubes have had 30 years of Gorillas tightening them, you might find the top flange (the bit the o-ring sits under) requires a bit of tap-o-metric attention. Dress it back down to a bit over right-angles again and it will improve sealing. Giving the plug end a bit of a straighten up is also handy, too.
Also have a look at the wiki: http://www.rollaclub.com/faq/index.php?tit...eries/Oil-Leaks
I tend not to use sealant though.
R
high temp red
or blue rtv
it may be solvable as red says, but its so much easier to jus goo them up
i used blue, but these days i use the red for everythin
basically the same shit only high temp red has a higher temperature bearing
i use threebond which is the toyota sealant. works great but at $30 a tube not cheap, but does go along way
