4k Tension Settings
Just wondering if anyone had any info on what tension all the main bolts in the motor should be set to such as big end and main and others
Cheers nathan
Thanks in advance
big end - 52 nm
main - 66 nm
others:
head - 66 nm
I had bothered to check the FAQ but those tension settings were for 3K motors and just wanted to get the figures for the 4K as i wasn't sure if these were the same figure. Before accusing people so not searching read what you yourself have actually searched
Nathan
big end - 52 nm
main - 66 nm
others:
head - 66 nm
NNNNOOOOOO.....
thats the lies the hanes spread
head it only 40-47 foot pounds or 6.6 kg-m
and the main caps 40-47 ft-lb or 6.6 kg-m
and the conrods are 29-37 ft-lb or 5.2 kg-m
sorry if 66 nm is 6.6 kg-m
but i stuffed my car around with the info in a hanes manaul and it cost me money
reading the pack the gaskets come in generally works for me.
NNNNOOOOOO.....
I'm pretty sure that 66nm is 6.6 kg-m
