camerondownunder88 Posted August 23, 2006 Report Posted August 23, 2006 Hi, I plan to finally be installing my 4K motor into my KE30 4dr Rolla soon. But While in the process of removing the 4K out of the car I tore the mounts. So to fit the 4K into my KE30 will I need to get new mounts or will the ones on my 3K motor in the car now fit the new 4K? As by looking at them they look slightly different so I don't know which ones to use. As apparently the KE30 was a bit slimer than other newer corollas. A wrecker near me also only has KE55 mounts so will these fit in if I can't use the 3K ones as there different? Cameron
Raven Posted August 23, 2006 Report Posted August 23, 2006 The difference between a 3K and 4K is that the 4K has bigger pistons. The block is exactly the same so the 3K mounts should work fine with no dramas.
Rolla__Boy Posted August 23, 2006 Report Posted August 23, 2006 KE30's are no skinnier. 3K and 4K engine mounts are completely interchangeable
Redwarf Posted August 23, 2006 Report Posted August 23, 2006 An Aussie 55 IS a KE30. Mounts are identical.
muller Posted August 24, 2006 Report Posted August 24, 2006 Had a 3k, it died. Replaced with 4k, got boring. Now with a 5k, never changed anything to do with the mounts
