checked here and there but couldnt find an outright answer so throwing the question out to anyone whos tried it before
have picked up a good ke15 bp head factory twin carb bla bla... you all know whats on them
still has original K motor and would like to leave that in it, matching numbers and all that (this thing WILL be doing targa tazzy)
question is, given block heights are the same (?) can i fit the 3K crank etc to existing block to up the cc's, will it fit, or is it like the 4K 5K where its all in the bore
if it would fit, will end result be the 10.7 comp ratio I'm chasing with the 3k rev and extra tork (compared to K at least)
PS don't ask for pics, this things been stored out in the open for the last 20 + years and looks bloody horrible at the moment
I wouldn't bother to much with the original motor. By all means give it a freshen up, wrap it in plastic and store it away for a later date if you want to return it to original.
Depending on class rules you would be better putting together a decent 5k or even 7k. Torque rules. You will halve your gearchanges with a larger capacity motor.
No fair, I want to see a photo - one will do.
I can tell you that K and 3K's use the same piston, so presume the capacity is in the crank?
G`day mate, its worth a look at the FAQ page to set your mind at ease on crankshafts/bore sizes.
http://www.superjamie.net/oldcorollas/engine/blocks.html
If my memory serves me correctly, the original 1077cc k motor only had a 3 main bearing crank. I think that was changed to 5 in the later 1166 2k motor.
I am building a 4k at the moment and was given a balanced 3k crank and rods and thought that I would use them and save a few bucks. As it turns out, the centre main thrust area is totally different to the 4k, so for that crank, no go.
You are doing the right thing by doing a bit of research and homework before laying out a whole bunch of bucks for nothing.
Mate, my original ke10 (I owned it back in 1972/73) was heavily modified and I continually revved it to redline and it never looked like letting me down. The car would go off the speedo by about half an inch and was actually faster than some of the rally datto 1600`s of the day. Please consider using the K motor that you already have. You`ll have a heap of fun with it.
Anyway, good luck with the build
you are quite right there old fella just like how a datsun a10 (datsun 1000) has 3 main bearings compeared to an a 12 ( datsun 1200) keep the origanal motor in it I'm spewin i have f@$kled around with my ke 10 2 door hey
hmm targa tassie hey
Your option would be to build it as a 17 replica and use a 3K. (Sorry Doug, original engines only!)
I had a 3K out to 1360 with a 4K crank, charade pistons (Can find sizing if interested). I know with a different piston we were looking at just over 1400cc, but I can't remeber what it was. Godd motor. Revved and had torque, particularly with weber-ation. Decent cam, go racing. Slight maching of the piston and head to make fit, ended up with 10.8:1, and ran 98 octane happily.
Few changes on KE17 they had rear vision mirror on drivers door, 1200 badge, and got a 3K that is off top of head think there are more.
Also since they were made later they could have a late model KE1X front end guards lower indicators bumper etc. Can be quite a few changes.
Also an original K motor has a lighter flywheel, original clutch cover has 60lbs more clamping pressure, Bigger cam in engine, higher compression head, water outlet for manifold heating under inlet/outlet port on cyclinder 4, no PCV gear, On back of moor the bolt lay out for the rear flex plate etc is different (I had to do a lot of stuffing abotu to get a 5K to drop into mine due to this easy fix but), engine number is in front of dizzy not behind...etc quite a few differences between a KE15/17 K motor and all other K motors. So hope that info can help. Feel free to ask if you need more.
Cameron
