gday peoples....
on the weekend i had a little bit of time to muck around with the dash lights in grover...i was sick of the green tinge they had because of the blue cover they have over the yellow globe. So i intended to fix it....by installing blue LED's into the bulb holders....thanks to Ruts suggestion (and the spare bulb he gave me).
the result was good :unsure:
:unsure:
just the dash cluster tim, it's easy as
is it just me or is that HEAPS brighter than stock? that's always sucked about corolla instruments, they end up dimmer than the tacho
i was thinking of changing over to just white LEDs in the ke25, but at $10/pair i had better things to spend the cash on at the time before i tried it
Do the ke55 like Grover have that pointed piece of plastic on each seperate guage like the ke30 series? :sigh:
Or have you removed it Xany?.......... :lmao:
its.....GOOONNNNNEEEEEE!!!!
lol....yeah i removed both and replaced them with flat plastic...i hate the look of them...
just for future reference, you'll need three LEDs to do this, theres one behind where the clock is, one behind the speedo and also behind the other cluster.
The lights are actually about the same brightness, it just looks brighter because the photo was taken in long exposure.
yeah, the pointed lenses look a tad wierd..... :lmao:
Sounds like a plan to me!
As Jamie said, the original lights are real dull - definately need upgrading.
Ill only need two, cause my clock is gone, replaced with taco and then replaced again with 5" taco + external shiftlight! :sigh:
you will still need three LEDs, i tried it with 2 and it just looks weird cause the left side of the speedo doesnt get any light. With the third one in, it looks a shitheap better.
btw, my clock is gone too..:lmao:
Edited by Xany
Oh, OK.....
I see now..... Ill try it one day. :lmao:
" No.. the taco... " Yeah, the external Taco gives me like 300+HP at all four wheels! ( <-- Insert Sarcasm here )
