Leaderboard
Popular Content
Showing content with the highest reputation on 05/30/17 in all areas
  1. Hi Kevin, The whole body of the car is the return path for all accessories to the negative terminal of the battery. Because the fog lamps & front turn indicators are on the bumper bar, both turn & fog lights will have an earth wire going back to the body, which I'm guessing is not grounded at all, or is rusty. When this earth is not present, both lights will try to work at the same time in series, which means each has 6 volts across it, which makes them both dim, & the turn indicators flash at a slow rate, because there is less current flowing through the turn indicators flasher unit. Do as Jon has suggested, & run a wire from the negative battery terminal to the turn indicators & the fog light earth wires, which could be a white wire. I'm guessing that the where the bumper bar bracket bolts onto the chassis is very rusty also. Let us know if that fixes it. Cheers Banjo
  2. If you follow the wires from the fog lights one of them will go to a grounding bolt (or possibly front turning lights ground wire which will then go to a grounding bolt) Remove the bolt, clean the contact faces and re-bolt it. I'm not familiar with KE30s but the wiring diagram shows an earth for each front turning light.
