Leaderboard
Popular Content
Showing content with the highest reputation on 04/30/18 in all areas
  1. I know what your after. Its the circuit diagram of the ECU and its sensors etc. The manual i have doesn't have it as such, but it does cover the pinouts on the ECU and the sensors. Its the full workshop manual for the 7k, its about 52meg in size. Can see about emailing it to you if you want it.
  2. CAUTION. All info here is assumptions So here`s what I'm thinking so far. Open for suggestions :rolls: Plug E5 Pin 2 +Batt battery fused permanent +feed Pin 4 FC Circiut opening relay (fuel pump) Pin 8 NSW Newtral switch for autos Pin 9 +B Ignition on + Pin 10 W Check engine light Pin 13 SPD Pulses from car speedo Plug E4 Pin 2 TE1 Check Connector (diagnostic) Pin 3 THW Engine coolant temp Pin 4 PIM Manifold Pressure Vacuum sensor Pin 5 THA Intake airtemp sensor Pin 6 IGT Ignitor "2" Ignition signal Pin 8 IGF Ignitor "1" Ignitor confirmation signal Pin 9 NE Dizzy Crank pos sensor Pin 10 VAF Variable resistor (if no cat)4-6K Pin 11 STA Starter Running Pin 12 Injector feed Pin 13 Injector ground Pin 14 RSD Rotary solinoid on TB- (idle speed) Pin 16 Grounds Pin 17 VTA Throttle Pos sensor Pin 18 VC Vacuum sensor + tps Pin 21 NE Dizzy Crank pos sensor Pin 24 grounds
