haydoss
  1. Keen for this! What rims are those? specs? cheers!
  2. Pretty sure i don't have any leaks. I'll try have a look at the cap aswell, thanks for all your help guys, much appreciated!
  3. Would this somehow contribute to high fuel usage?
  4. Pretty sure there is no exhaust leak, i've been checking underneath the car recently and no fuel seems to be on the ground, nor in the engine bay. I haven't got the carbon canister? i think it is (the black circular thing) connected, should i put that back in? and yes i've got an air filter on the carby. Thanks for your reply Evan! edit: and ae82! Hopefully putting the canister back in will fix it, thanks for your help guys!
  5. Hey guys. Lately while driving, i've been smelling fuel inside my car. I've had a look in the engine bay and all the fuel lines look alright and i can't work out where it's coming from. I'm pretty sure it only happens when i accelerate heavily.. anyway, any help and suggestions is greatly appreciated! Thanks, Hayden.
  6. According to the boost gauge, 10-11psi. Would there be much of a power difference with the 2 different pistons? dish shape i think it is? Once i have finished everything on it at the moment, might look into another dyno run and hopefully a lot better result lol.
  7. Seems like a decent goal. Well before i changed the oil to thicker to get rid of a flat spot, i had it dyno'd, but i forgot to put the choke back in haha! I'm pretty sure it made 68rwkw so hopefully with some adjustments mine could make 80. I was under the impression i could get 100, must of been dreaming haha. Good luck mate!
  8. looking goood! how much power are you hoping/expecting to make?
  9. haydoss replied to abbott's topic in SA / Adelaide
    Can i borrow yours? :P
  10. haydoss replied to Jared's topic in SA / Adelaide
    drove alongside a very clean willowy green early model corona from glenelg to hallet cove, with p plates and venetians. looked very nice!
  11. Cheers for the info guys. So i've found that SV21 shocks will go well with cut down (shortened) xt130 struts, is this correct? going to have probably 5-6kg springs. Thanks for all the info! Hayden.
  12. I think wheelworx? said around 180per rim, most places are around that price i think..
  13. rianwest - thanks for the info mate, was also needing a break upgrade aswell - thats why i wasn't going to do it on current struts :) nisrola - thanks for the link, unfortunately that is way out of my budget haha
  14. Hey guys, I've done a fair amount of research but haven't found anything definitive of what i'd like to know. Note: I'm doing this on a budget haha I'm looking at doing a coilover conversion to the front of my ke30 with the HSD coilover sleeve kit. I'd like the sleeve to be going on XT130/AE86 struts. What inserts should i be looking for to replace the existing ones? i have read short stroke camry? or celica ones, not quite sure what i should be looking for.. once again, i'd like the inserts to be cheap (lol) If i can't get a hold of XT130/AE86 struts, would ke55 struts/breaks be suitable for use of the coilover sleeve? Would S13 coilovers be cheaper to put in? Once again, sorry if this has been covered but i couldn't find the answers i was looking for.. Any help would be much appreciated Cheers, Hayden :happy:
  15. haydoss replied to abbott's topic in SA / Adelaide
    abbott - i'd be interested :)
