undercoverninja
Members-
21 -
Everything posted by undercoverninja
I have had the biggest steel mofo that repco has on the shelf, for the past few years, still working perfectly. You don't have to pull the handle out to release the valve, unlike the supercheap one. Not very low though.
Goes well, haven't given it a thrashing since its still being run in, but it pulls hard from 3k-6k (all i've taken it to). Seems to have a lot of torque down low, more then i expected. When I eventually make it to the track I'll know more :P. Carby and cam upgrades are always possible and easy enough with off the shelf stuff. All stock smallport except a trd 0.8mm hg, plus ignition and fuel.
Car made it out to AJD! Just got the new engine running too. Someone took this photo of it's new heart Still needs more running in, and i've got to fix some things like collapsing rad hose joins just before the water pump, etc. Going on a road trip in it next month then hopefully some track time will be had.
Updates. Rebuilding the smallport.
[Brisnorth]Need A Machinist Shop - Latheing Down Dizzy
undercoverninja replied to undercoverninja's topic in QLD / Brisbane
Yeah I'll ask the guy if he minds, when I get it done. Waiting on my head back atm. -
Cheers for a reply man, just found someone whom has done said work before though, thanks anyway :). -
Love the paint. And dat language filter ^.
Hey all, going 4kc dizzy on a 4age smallport, and I need to know the measurements from the base of the shaft (ha) (where it contacts the head) to the top of the dizzy gear. IIRC I read somewhere that the gears for old and new 4ages are slightly different, so don't know if that would effect the measurements, so please if you do measure the distance to the bottom of the gear as well as to the top of it ;). Going to try get a late model smallport gear from a toyota dealer or something. Shitty 4ac blew a headgasket, so it looks like it's 4age time lol. Also, swear I didnt type that thread title so retardedly. Hax.
Running and driving! Mate got a new car, a turbo ford laser, so we took them for a bit of a roadtest xD.
Electric (Low Pressure) Fuel Pump In Engine Bay.
undercoverninja replied to undercoverninja's topic in General Mechanical
All sorted! Thanks for all your replys guys, managed to get it all working well :D. If I had to name the issue I would say it was probably vapor lock from the long path from the pickup and the pump mounted at the top of the firewall. Cheers.- 14 replies
Looks much tidier, just above the tank near the rubber hoses between the tank and the hardlines.- 14 replies
This has been my experience. The old one was hardmounted to the firewall, and unless you knew what you were listening for, you couldnt really hear it over the sound of the (loud) 4ac lol. Until it started to run dry that is, at which point you could probably hear it 10 metres away over the engine noise. Probably did have some vapor lock going now that I think about it, considering that it was fine some times and not others.- 14 replies
Cheers for the replies guys, it is infact a Facet branded pump, shall get stuck into mounting it up underneath the boot tommorow. I swear I havent found a single thing done correctly on this godamn car since I started working on it.- 14 replies
Been having fuel starvation issues with my ae71, which has a weber carb and aftermarket fuel pump. Would I be correct in assuming that it is better to have the fuel pump near the tank? Seems it doesnt suck very well as it is, damn dodgy job the previous owner did xD. It's a brand new pump, old one died due to running dry and rust particles, lol.
- 14 replies
Drained the tank, boy there was a lot of crap in there. Mainly from the rusted fuel filler, but anyway, still broke at full load. Going to move the fuel pump from the engine bay to next to the fuel tank, should hopefully sort out all my problems (lol.).
Roger. Update: still broke, getting the tank drained and cleaned. Had a bit of a blast in it though, thrashing it around like a dickhead to try and figure out if it was still broken xD. Got smoked by a little green ae82 with some variety of 4age (assuming) lol, shortly after the line got clogged with shit again and it started getting fuel starved. In other news I am pretty happy with the way it drives, no abnormal rattles, stops very well, and you can actually feel the wieght transition, something i've never really experienced in my ae112 (aside from body roll xD).
Details/thread? I'd like to come along and meet some people, definitely. Pending work/uni/car problems of cause lol. Still havent got it back, getting a new fuel pump as apparently it has shat itself from the bits of crap it pumped.
Borgy though? Unsure how the whole diff assembly comes appart tbh. Paid far far too much, $1400, but oh well. Considering the money ive saved doing things myself/sourcing shit cheaply it comes close to evening out.
Imgur album: Figure I'll put a thread up here since i've lurked here for so long xD. This is to be my daily driver and is scheduled to be back on the road this arvo (pumped). I purchased myself an ae71 off boostcruising (lol) about 6 months ago. Just got rego yesterday, but broke down with fuel issues on the way home (filled up the tank for the first time in who knows how many years, stirred up shit in the tank that shouldn't have been stirred up). Leaving that to the mechanic because I really can't be ʞ©$ɟed xD. Recent pics: Semi recent pics: With these: Came with: - 4ac 5spd with a weber downdraft, ʞ©$ɟed radiator - cut falcon springs all round - 3 shocks - 3 working brakes - 3 seatbelts, two of which worked - resprayed exterior 2pac white. ok I guess, rust repairs bad. - no bumpers - locked stock borgy* - cut rear arches - ʞ©$ɟed taillights - ʞ©$ɟed everything What I've done: - A shit ton of maintenance - New suspension. MA61 struts and brakes up front (coilover sleeved), falcon sway and cut king superlow springs on the rear (captive), commodore wagon rear shocks, open stock borgy* - Pajero mc, braided lines - Hotwires in 14x6 - New tailights, wired up a dodgy reverse light set up with a relay from supercheap - Re-sealed the boot, did some dodgy-er rust repairs - Lots and lots of little things like window washer and steering boss Been a big job so far, and I'm still not quite at the part where it all pays off. But still a whole lot of fun and learning. Immediate plans is to get the fueling sorted, drive it, seal the boot lip properly as it has some leaks, and finish some bogging in the wheel wells, then drive it more. Future plans are e30 boot lip, some variety of black plastic front lip (FOH? idk), and when I can afford it (might be next year I'm poor), finish rebuilding the 4age smallport I have, and chuck it in with the weber and a 4k dizzy machined to fit. Want to to keep nice street manners and handle well, so I am a bit reluctant to put the locker back in, but also want to take it to give drifting a go, tis a dilemma. A few pics of build so far: not so SOON.
Hahaha shit I saw this in person when I bought some parts off you a couple of months ago, nice work on the rust repairs, even if you got lazy it's at least 50x better then what I did to the boot of mine :S.
