AE80Rollaguy
    347
About AE80Rollaguy
  • Birthday 07/01/1987
Contact Methods
  • Website URL
    http://
  • ICQ
  • Location
    Brisbane Qld Mt Gravatt 4121
AE80Rollaguy's Achievements
  1. |Ill sus it out and take some good pics of all the mounts for you mate Its the factory over flow bottle but re located it so i could use a bigger battery
  2. efi will fix that
  3. Hope this helps if not let me know and i will take a more detailed pic
  4. lol i get 2 weeks out of my dizzy :rolls:
  5. hey mate, most defs in the long run the turbo would suit the motor better, Ebay have some turbo manifolds to suint the 4a motor so that should get you out of that part (unsure of flange mounting) low mount manifold http://cgi.ebay.com.au/Kelway-4AGE-4AGZE-A...=item4aa0c8f432 high mount http://cgi.ebay.com.au/HIGH-FLOW-TURBO-MAN...=item563bf00c99
  6. i have had two ae90/ae93's, i had one dyno tested for 94hp atw, and my current one was dyno test with 125hp atw has NST pulley upgrade, Jazma headers, high flow s/s cat, rising rate fuel reg, stock injectors stock pump ABV mod done, and stock ECU so with all the other extra that the OP has on his car i thought he would be making a bit more than me? like people are saying get a good tuner to tune the ecu and the results could change..
  7. That would be good mate!, any chance of getting them on sat arvo or sunday? as I'm working all day tomorrow and will be doing the timing belt and sump gasket after work/ sat morn
  8. Yeah good point probs is i need the seal before i take the old one out as i need a running car
  9. aww thanks mate, would know the seal dimentoins off hand would u ?
  10. Hey guys, well as its says my distributor inner shaft seal is leaking, i have no i dea of where i could take this to get them replaced, i have bibbed on ebay for a seal set for about $30USD so I'm unsure if that is a rip off or not.... Much help would be nice Cheers
  11. A pulley "kit" will provide you with the water pump and tentioner pulley to leave stock rpm of those items I fitted the NST pulley kit and see 14psi with stock top mount and stock fuel system
  12. So me putting fuel in my car and using to it for a drive with my mates is a waste??
  13. nawwwww poor didums, well to me i thought doing a 200k cruise was better then going from maccas car park to another carpark to look at a home made flag was a point less trip.. end of rant
  14. +1 for me not showing as i am doing a sunshine coast cruise instead :>
