velociTOY
    20
Everything posted by velociTOY
  1. The 2T I'm using comes out of a TA40 Carina, and I guess the engine block mounts original mounted on the engine is a bit different from the TE7x one. Sadly. wde_bdy: Thanks for the inputs. From what I could understand the engine have to be mounted a bit forward compared to the original mounts, and about 50mm seems right. But do I have to remove the gearbox braces completly? I do have one more KE70 with 2T (on the other side of the country), and I can't remember that we had to remove them in that car? Anyhow, the important thing is that the gearbox tailshaft gets in the right position..
  2. Hi! I'm about to put a 2T engine into my 1982 LHD KE70 on the original crossmember. To minimize the work I would prefer to make the new engine mounts without having to lift the engine in and out of the car for measuring. There must be someone which have done a similar conversion, but the question is: Does anyone have drawings of the engine mounts they had to make? Appreciate if any could take the time to measure and make some drawings, and take some pictures. Buying a T crossmember is not a choice, sorry. Regards from Norway :jamie:
  3. Nice steeringwheel! Got any name on that one, or where to get similar ones?
  4. Damn pretty Celica! Didnt like the frontlight "cover" tho
  5. And the catchtank is ordered from....?
  6. And there you got the model himself! Haha
  7. OT, but who sells extractorss for 2T/3T?? I have found some cheap crap on ebay in the US, but i need something that fits in my LHD KE70 with Rack and pinion
  8. Hi, What are all the fuel lines on the catchtank for? in, out, return... and?
  9. Hmmm.. Hard to find here I guess.
  10. Hi, I have a T50 gearbox in my KE70, and want to get rid of the old clutchcable crap I have made. What parts do you suggest I use to get a proper solution? AE81 and AE86 parts are hard to find here in Norway. anyone got any pictures? EDIT: ment AE71
  11. Where did you buy the supercharger? Got any more specs/pictures on the engine? And I'll love more videos, cause your car is awesome!
  12. Hi! I have a Ke70 with a 1980mod 2T-B engine and T-50 gearbox. I bought a stage 2 clutch for 70 - 77 Corolla with 2T-C and thought it would fit, but there are some differences between the orginal set which I had, and the new set that I bought. The Pressureplate is identical, just a bit stronger The clutchdisk is almost identical but i guess it fits Pigot-bearing is identical BUT the release-bearing is different. The innerdiameter is about 2mm smaller, and the bearing itself is about 5mm thinner. Do you know if there is any difference between the t50 boxes? (Release-bearing and so on. know about the spline differences and shifter position and so on) Sorry for my crappy english :)
  13. Got any more pics of the engine?
  14. The 2 door ones is about as rare as the 4-door ones here in Norway. But its pretty hard to get AE86-stuff here. Like the A-bellhousing for T50 for example.
  15. Ke70 back to the "splitter" and then the S-series-ones from there. the toyotadealer over here never came up with the right parts for the S-axle when I rebuildt it, so something seems to be weird here. But it says S-series on the chassisnumber-plate in the TE71, and the diff is about 6,35" so I guess it is an S-series.
  16. 15x8 with +15 offset will probably hit the suspension. 15x8 with 0 offset doesnt hit the suspension, but might hit the guards if they are stock. I have 15x7 with 0 offset and 195/50-15 tires.. it works fine if you don't lower to much.
  17. And I'm jealous on your ke70 with 4AGZE! Do want! :y:
  18. Adjust carbs and ignition!
  19. Name: Vebjørn (Norway) Car: 1982 KE70 Corolla DX Motor & Driveline: 2T-B with T50 and S-series rearaxle from a TE71 Suspension & Brakes: Stock Wheels & Tyres: 15x7 Konig Rewind with 195/50-15 tires Interior: Almost stock Body: Repainted Red/orange Other: Daily-driver. soon to be project. Pictures:
