Everything posted by Harrycall
Weight Of 3tc Engine
Anybody know what the weight of a standard 3TC engine is? I'm considering an engine swap and want to do some weight calculations. Thanks
Team Science Ninja Racing Ke35 Corolla
The 6 hour is a pretty good event. Maybe we need another Corolla on the team next year!! Yep, the max laps you can do in one stint is 15. So we set a target of 10 laps per driver per stint (if you miss the pit board and lap over the 15 then there is a penalty). 2.07 is a good time. ithink my fastest (unofficial time ) was 2.11 with ignition issues, so there's more to be had once we eradicate the gremlins and set the car up properly. I'll try and put something up, but i'm a bit spasmodic with my posting as i'm busy with other projects/ work etc. By the way, i'm running a TA22 diff with an LSD. do you know of an easy bolt on disc brake option for this diff. Someone suggested Corona (can't remember which model)
Hey Adam, Welcome to Phillip Island in the wet !! Did the 6 hour event last year in the same conditions. Certainly keeps your concentration levels up there. 2.10 in the dry. Well done! Steve
Te72 (t18) Brake And Suspension Conversions
I'm going through the same process at present with a TA22 diff in a KE55 coupe. Looking to see what disc brake options i have for the rear. I've heard that 86 Corona are close to a bolt on answer but until i can get hold of some i'm a bit doubtful. I'm looking at doing the XT130 coilover conversion for my fronts. just need to figure out how much to shorten them by and where exactly to mount the threaded sleeve on the strut housing. Adjustable camber tops ready to go in as well. Any advice from anyone who's actually done these and have feedback? Coupe is a sprint/track car only. Thanks
Coilover Kits
Thanks for the feedback guys. I've got a pair of AE86 adjustable camber plates i'm going to use. Might investigate the SV21 option. Do you know how much shorther they are than standard KE55?
Coilover Kits
I'm looking at putting XT130 Corona struts into my KE55 sprint/hillclimb coupe and want to put adjustable coilovers on them. Does anyone know where i can get the kits fom? Also will this conversion bolt up to my existing steering knuckles or will i need to change them? Thanks
Lsd For T-18 Diff
Thanks Guys! So the search begins... Anyone out there help me out with an eary AE86 LSD Centre? Thanks :P
Lsd For T-18 Diff
I want to put a T-18 dif into my KE55 coupe. Width should be OK with the right offset rims. Which LSD centres will fit, and from which models? Thanks :P
Lsd For Borg Warner Diff In Ke55
:P Anyone know if there is an LSD centre that will go into a Borg Warner Diff in a KE55? Or alternatively, a conversion. Have contemplated a hilux conversion, but weight is a factor! Thanks
