Search the Community
Showing results for tags 'small port'.
I have a 4age, I believe is a small port with a MAP sensor witch means out of an AE92? It has the typical few leaks, tappet covers, sump etc Been trying to source gaskets and seals for it but am really struggling through the internet and places like repco. Most of all the 4age gaskets and gasket kits listed online and in stores are for cars like aw11 and ae82 witch are big ports (right?). so the basic question is will big port gaskets fit a small port? (apart from the intake manifold I'm guessing). And what other cars where released with my engine of future reference? also any good parts sites where I might be able to get them from? and has anyone else struggled to get a pug lead that goes from from the dizzy to the coil for a small port? they have like mini ends on them and i can't seem to find one separately, have to buy a whole plug lead kit? if so NGK best ones to buy or? thanks
- 4 replies
- gasket
- small port
(and 1 more)
Tagged with:
hi people, does anyone have the torque settings for the big end bearing and main bearing? or a full spread sheet they can email? the motor is a 16v small port 4age red top. I know these answer and probably on here somewhere but i have had a look and can't find them. thanks.
- small port
- 16valve
(and 2 more)
Tagged with:
Hi, I'm wondering (I may sound stupid) if there is such a 4agze that has the big port head but no T-VIS? The 4agze I'm looking at is in need of a full rebuild and its a big port head with CAS/DLI, what ever you want to call it, but has no T-VIS plate and the studs that the manifold go onto are not long enough to accommodate a T-VIS plate. So would this also help identifying what model car this came out of? I'm hoping its a late AE92 GT-Z levin... I know the AE101 had the small port head, but this is definitely a big port with no T-VIS. Thanks for the input!
